Allis B Belly Sickle Mower Seals
blue99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue99 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Belly Sickle Mower Seals
    Posted: 09 Nov 2016 at 10:50pm
 Hi,
      I am working on an Allis B belly mount Sickle mower.  I need to know how to get at the bearing seals on the main shaft.  I can see that the seal on the eccentric end is moving down the shaft......most likely needs to be replaced.  I see on the diagram that there is a pin on the pulley end......just can't see the pin.  So is the pin in between the pulley flanges?  Or is there a way to take  eccentric end off to get at the seal without working on the pulley?   Thanks,  John.
