D17 hydraulic screen
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulic screen
    Posted: 08 Nov 2016 at 7:31pm
Changing the hyd fluid in the new to me D17 SIV - drained out just a tick under 5 gallons between the two drain plugs.  Put 5 gallons of diesel in to flush it and let sit for a couple of days.  Pulled the plug under the right side and only got a gallon or so of diesel out.  Pulled the left plug and got a few drips.  I'm guessing I need to drop the sump and clean the screen?  Looking at ordering gasket #70233249 before I start.  Any suggestions?
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 7:47pm
I pulled that pan off mine and that screen was shot! The mesh pulled a way from the metal frame. It was no longer available from Agco. I ended up fabricating metal and reattaching the mesh screen. Something needed to be done. It worked. Ryan
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:25pm
The screen on mine was close to being completely plugged.
Not only that, but the ring magnet inside the sump had so much metal & debris on it, it looked like a Chia Pet.
Was surprised the pump even worked.
Like Ryan, there were some areas where the screen mesh had separated from the frame-work.
Soldered it all back up and after making the 2 gaskets, got it all together and it worked fine.
Gaskets are item 6 below.  Use plenty of Permatex #2 when assembling. That's alot better than silicone sealants.
And, Like Ryan said the screen is not available either.
If yours isn't any good, you might check around to see if any AGCO dealers might have one stashed away.
It's p/n  70242403  item 7 below
Otherwise, repair it so that the mesh is 100% complete.
BTW, I don't see a magnet on this parts breakdown.. IDK if that was an option ?
Edited by Gatz in NE - 08 Nov 2016 at 8:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 10:56am
Besides fighting with the pan that acts like its welded on, I have another question. Is there anywhere else for fluid to go? Since so little diesel came out, I would have expected to see some in the reservoir, but it looks empty. The trans level is still where it was before, so it didn't transfer. Do both plugs hold hyd fluid or am I misunderstanding the layout?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 11:14am
that sump casting can be a bear to get off.
I used a rigid putty knife and kept tapping it in all around till it finally separated.
Leave 2 of the bolts still engaged in the threads to keep it from dropping on the floor; it's heavier than it appears
Edited by Gatz in NE - 01 Dec 2016 at 11:16am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 9:15pm
Which filler hole did you put diesel fuel in, right or left?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 2:08pm
Left of the shift.
