30wt VS 15W40 oil pressure |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Topic: 30wt VS 15W40 oil pressurePosted: 05 Nov 2016 at 11:01pm |
Is it likely that you have higher hot oil pressure with 15W40 over straight 30wt? 15W40 is supposed to act like 40wt hot so that would make sense.Just wondered. I put 15W40 in my 220 last winter and used it for all fall work this year.It runs just under 60psi WOT and I could swear it use to only make 50 with the 30wt but,it's been about 6 years since it really got worked and I got CRS.
The 8070 is out of commission for the time being,ergo using the 220. |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 05 Nov 2016 at 11:11pm |
Uh oh...another oil pressure thread! Batten down the hatches!!
DrAllis
Posted: 06 Nov 2016 at 12:07am |
Not been my experience. 30 wt will carry a couple more pounds of hot oil pressure than 15W-40 does.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8283 |
Posted: 06 Nov 2016 at 6:28am |
Years ago, I owned a delivery truck (IH 2155 w/ dt466) that did alot of slow idle with a pto, in the summer I ran 30w, in winter 15-40, it alway's showed higher pressure even in the hottest day's with the 30w that it did in the winter with 15-40.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3123 |
Posted: 06 Nov 2016 at 7:13am |
I run 15W-40 diesel grade oil in every engine I own and when I change oil the first time in a tractor I buy the oil pressure almost always increases,of course i don't have any way to know what was running it when I bought the tractor.
ac45dave
Posted: 06 Nov 2016 at 7:20am |
thanks moderators.
Edited by ac45dave - 06 Nov 2016 at 7:27am |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 06 Nov 2016 at 7:21am |
2x LMAO |
ac45dave
Posted: 06 Nov 2016 at 7:25am |
i always found in my own experiences, straight weight oil to carry a little higher pressure than multi weight oils.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89172 |
Posted: 06 Nov 2016 at 7:51am |
the straight weight might have a slightly higher pressure than the 15w40. "Theoretically" they should be similar , but remember, the multiweight is a combination trying to solve multiple problems. The main advantage of a 10w30 or 15w40 is not the pressure when HOT, it is the advantage of thin oil when COLD to get the oil flowing quicker.
SteveM C/IL
Posted: 06 Nov 2016 at 8:51am |
That would have been my guess too.Kinda why I ask.I guess I'm okay with what it is but am a little puzzeled. |
