Question on 8030 Rear End Fill Tube
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Question on 8030 Rear End Fill Tube
    Posted: 01 Nov 2016 at 1:52pm
Hi-Does anyone know what retains this tube? Mine is loose but I don't see how to remove it. Is it retained with an oring somehow?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 3:08pm
Clean the tubes end and the housing bore with brake kleen and let dry. Red Loctite liberally spread and let dry overnite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2016 at 8:07pm
Before you lactate, find a socket with some taper and drive in tube to swell it, then do as Dr. Says.    MACK
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2016 at 6:27am
Yeah! Definitely do as Mack says. You don't want to get all excited and lactate!!! HAHAHAHAHA!!!!
*sorry MACK* I totally don't mean that to pick on you. I just thought that was hilarious!!!!
