2800 and 2900 Diesel Engine Difference |
dhs
Topic: 2800 and 2900 Diesel Engine DifferencePosted: 31 Oct 2016 at 1:22pm |
I have a 1966 190 with a 2800 non turbo engine that has had a recent rebuild. I also have a 1965 190 with a tired 2900 turbo engine. I would like to put the turbo and oil cooler from the 2900 engine onto the good 2800 engine. It appears that i have all the parts that I will need including the air cleaner. Will I also need to swap the pump and injectors and what other problems should I expect?
DougG
Posted: 31 Oct 2016 at 6:41pm |
There's something about a slug in an oil passage on the 2800 engine that has to be removed,,,,
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 31 Oct 2016 at 7:44pm |
Compression more than likely will be different, but I don't have the numbers in front of me.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
MACK
Posted: 31 Oct 2016 at 7:55pm |
The slug is in the 2900 to make oil go around to oil cooler on right side. MACK
DrAllis
Posted: 31 Oct 2016 at 9:37pm |
Compression ratio is the same between 180-185-190-190XTD.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 31 Oct 2016 at 10:26pm |
the tips are a tad larger in the xt, the pump is set to put out more. The water pump is located higher on the xt due to volute. Put the back galley plug in to make the cooler work.
dhs
Posted: 01 Nov 2016 at 5:58am |
Could you explain "put the back galley plug in" a little better?
MACK
Posted: 01 Nov 2016 at 7:08am |
There is a plug on left rear corner of block on 2800 block elbow on 2900. Remove elbow on 2900, there will be a long spring, then a plug. Remove and install in 2800 block along with elbow, line, and ect. MACK
DrAllis
Posted: 01 Nov 2016 at 7:10am |
When you remove the big oil line elbow at the left rear corner of the block, you'll see a long spring and deep down inside will be a blocking slug. Transfer those parts from one block to the other.
dhs
Posted: 01 Nov 2016 at 8:01am |
Thanks guys. It's always easier to get some advise before you do something for the first time.
