190 vs 190XT Lots of questions
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: 190 vs 190XT Lots of questions
    Posted: 29 Oct 2016 at 9:50pm
I recently purchased an Allis Chalmers 190 to resale and I didnt give it much thought to look under the hood to see if there was a turbo, I just did the normal stuff check oil and etc. Anyway when I look up the serial number, 10727, it tells me its a 1966. The decals say 190, and the serial number reads 190   10727. But according to Norms book that serial number falls under the 190 xt with the bar grill. This tractor has no bar grill though. When I look up the number under tractor data it doesnt separate the 190 from the XT. It still lists it as a 190. Anyway I am totally confused. Can you guys enlighten me a bit on the 190 serial numbers.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 9:53pm
Well...I can't help your ID problem, but since we don't really know what it is, I'll give you $50 cash for it, sight unseen in person! Lol (Remember: Thrifty, not cheap!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:05pm
LOL I dont think so. It is really a clean tractor and runs great. Probably going to ask more than $50
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:06pm
I think 190 xt serial number had xt in the serial number, 190s no turbo, some other differences but someone else will elaborate.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:12pm
It has a turbo.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:24pm
I'm sure the serial numbers all ran together.  For example 10,727 could be a 190 and 10,728 could be an XT.  However, the XT all had either XT (gas tractor) at the end of the serial number or XTD for a diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 10:34pm
I'll make you a deal you can't refuse...how about $75....AND...a good rebuildable "B" cylinder head?? LOLLOLLOLLOL
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 11:04pm
That's an XT engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 11:09pm
as the years pass....things get changed on old tractors
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 11:10pm
i'll bid $101. dollars and throw in the front 1/2 of a 1950 1 ton Dodge truck w/o the engine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 12:57am
How can you tell its a xt engine?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:31am
the 190 (Gas and Diesel) series had their own run of serial numbers
The 190 XT (Gas and Diesel) had their own run of numbers
you can have the same serial of say 9000 but only the ending characters will tell you more
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:32am
The Grill probably fell off at some point and they used a later series grill since they fit right on.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 6:29am
There should be a metal tag riveted to the block near the engine oil fill tube. A 190 has a G-2500 or D-2800 engine. The 190 XT would have a G-2800 or D-2900 engine. With the paint job (hood decal), grille and chopped fenders, it's hard to tell what engine it might have. Might be a combine engine transplant.
JFREED View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JFREED Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 7:43am
Is that an access hole to air filter above right front tire?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 8:00am
Is that a Dodge Power Wagon you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 8:09am
You can clearly see the oil cooler and turbo oil lines of an XT. The air filter access hole in the side cover is an early serial number design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 8:20am
I ran into a an issue decoding my 190xtd. I found differences from my engine verses my brothers 190xtd even thou they were only 4 series numbers apart. After noticing the head had a rear water jacket plate, I also found when I pulled the injectors to have them rebuilt, I also found brass sleeves in the injector ports. My understanding is that came availible in the 7000 series engines. Injector tips coded as out of a 7010. So, I am guessing that I have a transplanted 301 out of a 7010 tractor. Engine seriel number is in the 85,000 range. Still runs a 190 xtd injector pump. Whom ever did the transplant timed it incorrectly to 18 degrees btdc, the xt pump does not advance 10 degrees. I changed the timing to 26 btdc and it ran and started much better. If you would like to find a period correct bar grill and would like to sell that nice screen grill i would be interested in buying it.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 9:07am
Yes, that is an XT as the engine has the oil cooler and oil lines going up to the turbo.  Nameplate on the left side should say model 2900.  The decals do not indicate XT because those are not correct decals (look homemade to me). The 1966 should also have a bar grille, but good ones are very hard to find and they often get replaced with non-bar grilles from later 190s, 180s or 185.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 3:17pm
So what are you asking for it ?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 10:38pm
I've never seen a 190XT with a muffler....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 11:15pm
Thanks for the info. The serial number on the side reads 190 10727, so after some great input from you guys I actually looked and there is a turbo, just like yall said. I guess thats what I get for assuming, right? So its a 190 with a 190 xt motor. Mystery solved. And again thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:53pm
The 190 tractors with cab's came with muffler's to deaden engine exhaust from ringing thru the cab. The cab's had either no insulation or thin padding to act as an insulator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 6:57pm
If it was a true XTD from the factory it would be stamped after the serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2016 at 7:12pm
All One-Ninety's had a muffler of some sort. Older ones had muffler under the hood. Late models were above the hood. No One-Ninety XT diesels ever had a muffler, period. Many got a 200 muffler added on, but the XT diesels never had one from the factory.
This page was generated in 1.559 seconds.
