never seen this before.... |
   shameless (ne)
   Joined: 08 Jul 2016 Location: nebraska Points: 7463  |
      Quote   Reply
     Topic: never seen this before....Posted: 29 Oct 2016 at 3:53pm  |
   a 9 shank ripper on a 2 wheel transport pulled behind a 4x4 tractor! tractor had a 3 pt hitch too! sure sat back away from the tractor aways. must work!
   Dswall
   Joined: 11 Jan 2014 Location: Lindsay ca Points: 260  |
      Quote   Reply
     Posted: 29 Oct 2016 at 4:36pm |
   That's the way we rip. Works better with a dolly when the hired help is running it. When you hit a hard spot the tractor spins and sinks then the ripper is deeper and then you pick up on the draft control and the tractor comes out of the holes it dug and the ripper is out of the ground! And it's easier on the rear end of the tractor!
   Dakota Dave
      Quote   Reply
     Posted: 29 Oct 2016 at 5:19pm |
   That's how it's done here also. Most farms use either a Eco tiger or stinger tiger for a ripper a 9 shank wieghts around 9,000 lbs. only one of our articulating tractors has a Three point. The only thing I've used the three point for is moving one bale at a time when it was to soft to get in to the hay stack with anything else.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
