D 19 factory 3 point question
orangeace1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeace1 Quote  Post ReplyReply Direct Link To This Post Topic: D 19 factory 3 point question
    Posted: 25 Oct 2016 at 4:02pm
 I have never seen any literature of a D-19 with factory 3 point. Does someone know for sure (not I think)  when AC made a 3 point available on the D19?
Have these AC tractors: 2 WC's styled,one with AC bale loader.WD with AC frontloader. WD45gas, 2 D17 s4's gas. D19 gas w/cab,190gas w/cab,190xt sIII w/cab,210 w/cab, 7045.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 4:11pm
Yes, and I have literature on the second to the last page that shows it as an option. Early model D-19's it was not available, as is evident by the lift arm housing not having the four bolt holes for the top link bracket to attach to.
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 5:39pm
I have a brochure for field cultivators and it has D19s with three point. One photo has one mounted up on the three point hitch and the D19 is transporting it down a road.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 5:43am
I have an earlier D-19 that I converted to 3 pt. when I bought it 25 years ago. Had to change the rock shaft housing to mount the top pink. Everything came from a One Ninety.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeace1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 12:19pm
Thank you.  Any way you could scan that picture in your lit. and email to leob@maxumgrp.com   Also do you know about the month and year that option came out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeace1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 12:54pm
Thanks. Any way you could scan that photo and email to leob@maxumgrp.com.
Orangeace
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 8:23pm
These are from various brochures dated 1963.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 4:27pm
My D-19 tractor literature that shows a 3-point hitch (and position control lever) is dated April of 1963. It is shown on page 24 near the back of the brochure. Nowhere else does it show the hitch being used with an implement attached.
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 4:34pm
Yes you could get them with 3pt,i had one.
