Off color (IH) question
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Topic: Off color (IH) question
    Posted: 24 Oct 2016 at 2:10pm
A friend of mine has an IH 300 utility tractor with a loader on it. He parked it one day to go eat his lunch. When he restarted it, the clutch would not disengage. Clutch pedal and linkage looks/feels normal. He wants me to fix it for him, so any info on these would be appreciated. Did these have a two stage clutch that stopped the tractor while the PTO continued to run? Thanks.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 4:48pm
I don't know for sure but the 300 basically replaced the H I didn't think it had live power I thought that started with the 350. Could be wrong. Has he tried to break the clutch free by all the fun methods like chaining it to a stump? It is sort of hard to believe that condensation and rust would be the problem if he was running it just hours before it froze but it is the most common reason why they stick. Normally it is after sitting all winter though.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:08pm
Sound like the throwout bearing may have ate fingers on pressure plate. I think it is a single clutch and also live pto. Been a long time since I drove one in the late fifties
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 6:07pm
I have a 300 utility that I redid about 15 years ago. New clutch, redid the TA, resealed the trans, rebuilt motor and power steering. I use it a little but not much. The clutch is a standard dry plate setup. The throwout bearing retainer has a lockbolt that holds it on the shaft. Could be that has loosened up but you would probably get a light pedal feel. They do have a nice cover on the bottom you can pull off and look at the bearing.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 6:54pm
Weren't the TAs notorious for going out on those?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 7:01pm
The Independent PTO is driven by a hollow shaft that is splined to the main clutch cover. The transmission shaft is inside the PTO shaft and is a a conventional single stage clutch.
I suppose it is possible that it has a non-independent PTO, like the 'H'. I think it was an option. But the clutch is definitely not a two-stage.
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 5:12am
The thing I see on clutches that won't release is the dampner springs in the spline hub break and jamb the disk to the flywheel or pressure plate. Usually the clutch pedal feels about the same but the wheels keep puling. I have seen them go ahead and fall out and the clutch resume working as before, but the thing ought to be fixed for the sake of safety and the life of the trans and drivetrain.
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 6:32am
        most of them went out because people didnt know how to use them
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 6:49am
Yea they were about as reliable as the AC torque limiter (Stock ones worked good when used lightly but were prone to give you finger at the drop of a hat anyway)  but at least the factory had kits to eliminate one all together.
On top of that they did serve a useful enough purpose for a whole aftermarket industry to come to life and stay alive manufacturing far more improved designs to solve the weak factory TA design issues.  Tongue
AC torque limiters on the other hand.... WellI have yet to ever be told of a aftermarket improved design or eliminator kit yet.  Disapprove
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 6:58am
Yea they are not two stage in the standard sense but the main clutch and TA clutch  linkages are tied to the foot pedal and can be setup to work as a very handy two speed clutch!
Full driveline disengagement at full clutch pedal travel with the TA on at half travel and full speed at full release.   I've set up many tractors for people that way and it's very handy. Especially on loader tractors.
Once you get familiar with it you rarely ever pull the TA lever unless you need it active for a long time.
It also keeps the dang things exercised so they are a bit less prone to giving up from lack of use. Wink
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 7:50am
I've had a clutch disc stick to the flywheel face when sitting all winter.
Dusty
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 11:56am
Does it still go when in neutral?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 12:32pm
Pilot bearing?
