Rebuild Hydraulic Cylinders CA
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Rebuild Hydraulic Cylinders CA
    Posted: 21 Oct 2016 at 8:39pm
Is it hard to rebuild these cylinders?  Mine are leaking and I've tried tightening the nut over the "piston"  with no change.  Who carries a rebuild kit?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 8:45pm
Pretty easy job I got mine from sandy lake implement
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2016 at 9:14pm
Any local hydraulic shop should be able to get what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 4:51am
Thanks for the suggestions.
1940 B "Lucy"
1972 314H
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 9:17am
I ask on here and got several responses, ordered them for the WD45 off the first fellow that responded. Got them in a few days.
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 10:04am
As others mentioned most any hydraulic shop will have what you need although if they are by chance some odd ball non standard seal design it may be necessary or at lest way cheaper to have a bit of machining work done to refit a more modern and common seal set put into them.
I've done it a number of times now with old hysraulic cylinders over the years. Most times it was simply due to a hard to find OEM style seal being rather costly, $100+ Vs a common and better designed $10 seal set that could be refit with some simple machining for <$50.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 10:36am
Got my seals from djs tractor parts and put them in myself. No big deal
