Tire and Wheel weight - D17 |
Hockeygoon
Joined: 13 Sep 2016 Location: Manhattan, KS Points: 1210 |
Topic: Tire and Wheel weight - D17Posted: 20 Oct 2016 at 12:02pm |
What does a tire and wheel weigh that is loaded with fluid?
This is a 16.9X28 tire and wheel from a D17. Trying to set up a plan to pick it up this weekend. |
DrAllis
Posted: 20 Oct 2016 at 12:29pm |
FULL fluid?? is about 500 to 600 lbs just for the fluid in one tire. I'd expect the tire/wheel and center to be maybe 400 lbs?? make a diff on what brand of tire and how worn out it is.
Hockeygoon
Posted: 20 Oct 2016 at 1:21pm |
I have no idea how full - just found a tire with a decent rim and the owner says it has fluid in it.
DougS
Posted: 20 Oct 2016 at 1:39pm |
Leave the tractor out on a cold night. You'll see exactly how much on a frosty morning. |
Brian G. NY
Posted: 20 Oct 2016 at 4:46pm |
I hauled two "loaded" 16.9 X 28 D-17 wheels in the back of my '93 short bed D-1500 Dodge. Definitely more than a half ton but not the biggest load I've hauled with that truck.
Hockeygoon
Posted: 20 Oct 2016 at 5:09pm |
I was curious if my son (age 14) and I could throw it on the back of the pickup - 900 to a 1000 pounds is probably a little more than I feel like trying to manhandle at this stage of my life.
dawntreader74
Posted: 20 Oct 2016 at 6:45pm |
you may be able to roll it up a ramp of some kind' two guys if you hold your cheeks together you may be alright''
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 20 Oct 2016 at 9:46pm |
I would try to get some sort of lift. If anything goes wrong someone will get seriously hurt trying to roll that much weight up a ramp.
Brian G. NY
Posted: 20 Oct 2016 at 9:50pm |
I would not recommend attempting to load it without a lift or loader of some type!
If it gets away from you, it could result in serious damage, bodily or otherwise.
Dan73
Posted: 20 Oct 2016 at 10:06pm |
You might be able to roll the tire to the back of the truck tip it against the tailgate then use a come along to winch it up into the truck. That would be pretty safe.
dawntreader74
Posted: 20 Oct 2016 at 10:46pm |
back your truck in the ditch will sure help a lot ' it mite just flip on the tail gate' it will be close to the ground that way'
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 21 Oct 2016 at 7:19am |
According to the Good Year tire book, if the tire is filled to the top of the rim, the fluid alone weighs 747# for a 16.9-28. Add 100# for the rim and wheel center, and you have about 850# max.
HD6GTOM
Posted: 21 Oct 2016 at 8:39am |
you need a tractor with a loader, skid loader, etc and chain. set it down gently in the truck. If you roll them in and let them flop against the side they can put a big dent in the side of the pickup box. Seen it happen several times when guys brought them to us to fix.
alleyyooper
Posted: 22 Oct 2016 at 7:44am |
I would not put that kind of weight on my pick up tail gate. Would remove the tail gate use some 8 foot 2x6, 8 10's as a ramp. hook a come along to the front of the bed some how maybe hard wood stakes in the pockets and ratchet it up on its side while pushing from behind.
That is lacking a lift of some sort. Al
