Mylar vs Vinyl Decals
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Mylar vs Vinyl Decals
    Posted: 18 Oct 2016 at 5:45pm
I've heard about different types of decals, and I don't know much about them. I hear a lot of folks say they don't like one or the other. What's the big difference in the two? Advantages/disadvantages?
Thanks
Edited by CrestonM - 18 Oct 2016 at 5:46pm
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 5:53pm
Mylar is cheaper but tends to fade. Vinyl is more expensive but lasts a lot longer and looks better. I personally despise mylar decals.
Adam
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:17pm
If you are going to take the time to put decals on your tractor, spend a little extra and get good quality vinyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:18pm
Not needing to...yet...maybe this spring. If I paint the tractor, it will be a working paint job at best. Just something to protect it. It will be barn kept though, so fading shouldn't be to much of an issue. There's not much of the last paint job left (brush painted 30+ years ago)
Edited by CrestonM - 18 Oct 2016 at 8:19pm
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:39pm
Vinyl decals if was mine for sure
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 9:20pm
mylar is cheap thats all i will say
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 7:26am
The Mylar decals are thin and fragile but if you clear coat over them they look great and are protected. If doing a single stage paint then vinyl is the way to go as the decal is on top of the paint.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 8:21am
A thought I heard clear coat will change the shade of the decal color, especially white.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 9:19am
I have not seen that with the ones I have done so maybe it depends on what type/brand of clear coat was used?
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 11:06am
I saw this yesterday and remembered to check Theissen's for decals for Creston. You were wanting the older all gold A-C decal right? They only have them in 2". They have the orange A-C decal in 6" and 2".
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 11:33am
Thanks Brian, but I ordered two of the 6" blue/gold ones from Jensales already.
jange01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jange01 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2016 at 12:55pm
I've used both, probably 5 sets of Mylar and 20 -- 25 sets of vinyl. As others have said, vinyl is a better decal. With Mylar, there is a clear square or rectangular background for the decal. The letters are printed on it. When applying you spray the sheet metal with water or window cleaner so that you can squeegee the air bubbles out. This also allows you to slide the decal around for correct positioning. Be careful though as they are extremely thin and can and will fold themselves over and/or bunch up. I've seen Mylar applied without water - looks terrible. Impossible to get the air bubbles out without this process. You will still see the clear background to some extent.
Vinyl usually ends up being just the individual letters when you're finished. There is a piece of paper on the top of the vinyl decals. You peel off the background from the back side, the letters saying on the front sheet. You then carefully position the paper, burnish the letters on, then peel off the front paper. You cannot slide the copy around once stuck on so align carefully.
Jim
