D19D rebuild
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: D19D rebuild
    Posted: 13 Oct 2016 at 8:24pm
Here is a video of my D19D after don Bradley rebuilt it. The pistons, piston pins, sleeves, rings, turbo and injector tips are new, the pump was rebuilt, crank turned, newer used fuel cells, a newer exhaust manifold and thermostat housing. I need to get a taller exhaust stack to save my ears! I also have a nos Hobbs hour meter that is turned on by an oil pressure switch so I can keep track of actual hours on the new mitor
I can't figure out how to get a hot link but if you copy the following address and paste it in a new window I t will take you to the video.
http://www.youtube.com/watch?v=s0TNH4PFP_E&sns=em
Edited by Michael Crowe - 13 Oct 2016 at 9:02pm
Jerry H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerry H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 8:37pm
Glad to hear you got it done.   Don sure does good work.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:27pm
I hope she gives you years of trouble free service! This rebuild was a little tough to do with none of the newer D-19 pistons with the valve relieve out there to be found, so we did the next best thing, milled the set of older ser # NOS D-19 pistons he had in-stock to work with the newer head/camshaft, then decked the block and re-cut the counter bores.
I think it turned out fine.
[TUBE]s0TNH4PFP_E&sns=em[/TUBE]
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 10:01pm
I could listen to that all day!!
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 4:08am
Boy, that was some heavy duty grass and didn't miss a lick. Don does know his stuff on these Allis's.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 6:22am
Impressive.   I wouldn't want to have taken on that job when you can't buy the parts anymore it takes a real pro to make them out of something else. Very cool to hear it running. Definitely nice to hear a diesel that doesn't sound like the valves will explode like the old detroit we had in a truck here when I was a kid. Sounds great to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 9:40pm
I just got the hour meter installed; I plugged the meter in to account for the 4 hours I had on it before I got the meter in. It runs of oil pressure so it should very accurately track the number of hours on the rebuilt motor.
If you copy and paste the following you can see the video
http://youtu.be/73guklgH0_U
Edited by Michael Crowe - 14 Oct 2016 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 10:04am
This how the inside looked as it was built, note the piston tops and you can see the mill work done to them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 5:45pm
Very nice! Don does a great job!
Thanks for posting! Your D19 tractor is awesome!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:06am
If you don't have low hanging trees you work under, also turn your rain cap around, and that should knock the sound you hear down at least a bit.  It looks like it is reflecting towards you.
Still in use:
shackratt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shackratt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 12:09pm
Awesome!!!
AC 180, TO-20, Case 580B Case 450 dozer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 5:25pm
I put a 3' pipe on it and did just that, turned the rain cap donut pushed the exhaust and sound forward; much better on my ears.
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:42pm
Michael. I did find one thing wrong about tractor. It is western,Mo and not in eastern,Mo. Ha!Ha! Nice tractor Michael and great job Don.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 8:17pm
I got to look your tractor over when I stopped by Don's last month but didn't get to hear it run. Sounds pretty darn good.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:33am
Now that is awesome! !!!!!Darrel
bigredisb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredisb Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:35am
That sounds soooooo good!
1961 Allis-Chalmers D15
1949 Farmall Super A
