K2 small grain kit
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Topic: K2 small grain kit
    Posted: 12 Oct 2016 at 6:50pm
Does anyone have some lit. or pics for installing and adj. on these things ?
I read the entire owners manual and the kit is only mentioned one time and no details. I have the top one installed but the bottom one seems to be stumping me ! ANY help would be great !!! thanks
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 8:25pm
May not be much help, but in the Parts Catalog under "Fan" it shows the parts for the Small Seeds Kit and their locations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 9:23pm
What are you trying to harvest?       MACK
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 9:40pm
Thanks Jim , that does help !
Mack , next years fescue. I had always used the old Ks and this was not an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2016 at 9:50pm
After seeing where you are from I should have known. That's about all that is combined in your part of Mo.     MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 9:11pm
for fescue we have found a simpler solution.   1. lower the flap or air choke all the way down and measure from side to side and from the ledge in front of the fan to the choke.  Now go to a sheet metal shop and with the same gauge metal as the choke have a rectangle shoe box like lid fabricated with the same dimensions only 1 inch taller. Drill holes in the side  and bolt the new restrictor in with the lower edge outside the lower fan housing so as it cannot be sucked into the fan - bolt the sides to the side wall.  Now the choke can be lowered to the piece and it will close off all air - which you do not want to do, but you can now shut off as much air as needed.
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2016 at 7:56am
Sounds like that works but, I got all the pieces of seed kit in .If a guys arms were four foot long it would be an asset putting them in.If I need more restriction , will give yours a try. thanks
This page was generated in 0.110 seconds.
