Give me the low down on the MF 85 |
Post Reply ![]() |
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5105 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Oct 2016 at 7:07am |
One for sale local and I'm looking to sell my Long and get something else. I've read they're orphan tractors and parts availability is limited. Is this certain parts or all parts. It's a 4 cylinder Continental but I don't know if it's the early 223 or the 242. I'm looking for something to run a 6ft Kuhn disc mower and a NH 273. What do you guys think?
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
Hmm, do you know how the "live" PTO actually works? I'm guessing, and only guessing, it is like the 1968 MF 165 we had. You put the foot clutch 1/2 way down to stop the ground transmission, all the way down would stop the PTO. That was a pretty piss poor system IMO. So, IF it's like that, I would stay away. Our 165 did a poor job of baling, like the PTO clutch was "mushy", and sheared a lot of bolts. Same baler as you have! According to Dad, 1 year later, the 165's came out with a true independent live, and was much better.
Even at that, I'd think she might struggle with your disc mower a little bit......IDK Maybe I'm all wet. I would check out how that PTO works for certain though. If it isn't like my 165 was, I wonder why the heck they did away with something "superior" for a few years, then came back to it? |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
I never actually used an 85, but I used a 235 and 245 a LOT. It looks like the 85's are similar just older. Think of it as a Ford with an improved transmission. Most of them are a 3 speed with a high-low for 6 speeds. The low range is really slow and grannyish which is great sometimes for mowing forward and back around stuff. Also nice to backing wagons slowly and such.
I don't know about this one, but the later ones 135, 235, ect Did have the 2-stage clutch. I liked it. Not quite as nice as a true live-PTO, but you could still shift with the PTO running. IMO better than an Allis that you really can't shift with the PTO running. They make a great little utility/mowing tractor. |
farmtoybuilder ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
A 165 would be much better than 85!! We sold MF when 100 series came out and they were a Great tractor! old 85's are obsolete! Parts are hard to find and get and I wouldn't want one. Most people loved the 2 stage clutch on 100's! Running a baler isn't a problem with 2 stage clutch! I prefer it over hyd. ones for lasting and low cost to fix.
Ok. I'll pass mainly for the obsolete reasons. Parts availability is the main reason I'm selling my Long. Don't want to sell one and wind up in the same spot. Thanks y'all
Since you sold the 100 series, what are the things to look for on the 165 and 175? |
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
http://www.importtractorparts.net/Long.html Have you checked out that site? I was looking at a long recently and didn't buy it because I wanted the 4 wd and they said it was the one thing they really couldn't get parts for but it seems like they could get alot of the other parts. Might find what you need there. I think if you could get parts some of the diesel longs would be nice tractors. |
That's where the parts for the engine rebuild on mine came from. Problem is that's about the only place to get new parts and they're a long way off. If I needed parts in an emergency case I'd be SOL. With Massey, Ford, Case, International, and JD, I'd at least have a chance of finding something within driving distance.
Well, that certainly wasn't our experience with the 2 stage clutch.
I guess that's why there are opinions, to each their own. Tractor data said they were a 8 speed, not the hi low 6 speed. (And ours had the multi-power for actually 12) |
There were different transmission options, at least later one. Grand has a 235 6 speed and a 245 8 speed.
I should probably say now, that the 2 stage clutch isn't a factor anymore. Either the PTO cluch is bad or the pedal has so much play in it that it never hits the 2nd stage. Just have to shut off the tractor and start with the bushog engaged |
Yes on your 235 and 245, but on the 85 that the OP asked about? I've never seen that. |
I wish there was hope of driving to get parts for anything. Well maybe if I buy kobota but that is the only dealer around here so all parts are mail order for me.
Post Reply ![]() |
