Help identify tractor
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: Help identify tractor
    Posted: 09 Oct 2016 at 8:34pm
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:38pm
Looks like a D10 or D12
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:40pm
no can over the muffler, and with the hood loose, looks like someone found out it sure don't run anymore!
Randy_Larson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_Larson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:54pm
D 10...it doesn't have the spin out rims....check the serial number to be sure
G,D10,D12,D14,D15,D17gas,D17 diesel,D19 Diesel, D21 Series II,160,190, B1,Bumble Bee 10,B1,HB 212,ACC 30 forklift and snap-coupler equipment
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 9:13pm
I would like a translation for the word, "couple."
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 9:23pm
A couple years before the turn of the century, the same year the can blew off the exhaust.
Allis Express participant
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 2:14am
Ever how long it takes grass to grow that high in Georgia.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 2:40am
Very straight sheet metal and a 3pt adapter,probably worth close to what he's asking for it.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:26am
probably going to part mine if you need anything...
Mine'd have to have the engine rebuild as the sleeves had pieces missing in the bottom.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:45am
If it ran it might be worth that, I can't see anyone paying anything close to what he is asking for it in that condition and not running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 8:15am
ANY 'non running' aka 'ran when parked' tractor ain't worth more than 500 Canucks to me. It's the 'little things' like condition of engine, rad, tranny, rear end, hydraulics,brakes,etc that CANNOT be tested until the engine runs. assuming it has been sitting for 2-3 years..guess how much water is IN the engine,tranny, etc. It could easily turn into a money pit or be a diamond in the rough but unless you can afford to blow a grand on rolling the dice.........
Jay
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 8:28am
The tractor is a D10 Series I.  From the battery located behind the seat and the early type seat, it would be a 1959-60 model, below serial number 2236.  If you want the tractor for yourself at a $1000 offer, it would be an okay deal.   Parts would bring around $2000.  The big problem is that you will not know if it jumps out of gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 11:36am
Thanks everyone for the info and even the value estimates.  I'm not familiar with this model.  However, I do know that parts are not as readily available for them compared with the Bs and Cs.
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 11:37am
Jay
I've been taking chances on tractors like that for about 40 years and the vast majority have worked out pretty good,plus I'd bet a cash offer for right much  less would get it bought.
D10 parts will sell for a decent price sooner or later as most people want to fix their's up
not part it out.I'll take a tractor like that over a doctored up POS with a spray can paint job anytime.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 11:38am
Looks like an early D10. I was looking at it last night on Craigslist. I would say around $500 as long as it has been sitting unless someone needed it for parts. I have enough projects right now so come on up and get it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:18pm
You'd have to go look at it and work it out. Like Larry says, I'd not offer more than that. I'd start out lower or if you really want it, take the $1000 with and go see it.  Looks like ?? decent tires and metal.  Hard to say from the pics. How bad do you want it Steve?
This page was generated in 0.115 seconds.
