Allis Snap Coupler Blade Help
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Allis Snap Coupler Blade Help
    Posted: 09 Oct 2016 at 9:19am
Bought a snap coupler blade without the lifting arms, (pic for example below) today.  Anyone have a parts blade or extra set theyd like to sell me?
Thanks
Steve
Edited by Steve-Ohio - 09 Oct 2016 at 9:21am
sling-it View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sling-it Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 10:13am
With some measurements, those could be made by a blacksmith pretty easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 6:03pm
or one of the bigger plows, at a junkyard might be close...
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 4:18am
Are you missing everything, or just the flat bits above the round bar?
I can get measurements from mine if that will help you.
Robert
B W in Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B W in Mo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 6:24am
All he needs is the lift arm latches that go on the tractor.
B W
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 8:29am
A piece of 5/8" rod welded to a 1 1/2" x 1/4" flat bar stock with a hole drilled in the end will do the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 8:33am
hmm..always wondered which WAY those things are supposed to go on, as they are 'offset' front to back ????
Jay
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 10:56am
I have these ends if they help .U can take them off the rods .
Edited by Fred in Pa - 10 Oct 2016 at 11:00am
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 12:32pm
Jay, in Fred's second pic, you can see the hump at the left side of the pic.  This is the side that goes into the snap coupler arms. You can tell by the top pic from Steve, the hitch eye is pointing at us.
Edited by Ted J - 10 Oct 2016 at 12:35pm
