Gleaner E Fuel Pump
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E Fuel Pump
    Posted: 05 Oct 2016 at 8:20am
Our mechanical fuel pump has finally given up.  According to the dealer a mechanical replacement is no longer available and we would need to convert to an electric fuel pump.  I have a blank off plate ordered for the block once we remove the old pump.
I'm not an expert when it comes to equipment electric.  This is still 12 volt, positive ground.  What type of electric fuel pump should we buy?
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 8:31am
I am not a fan of the "clicker" type pumps and prefer a good rotary like a Carter. You need to specify a low pressure pump like the one sown in this Ebay link. Notice ithas two wires, that means it isnt grounded through the case and you can use it on a  positive ground system by simply keeping the + and - correctly wired, ground the + and provide power to the -
http://www.ebay.com/itm/Carter-Fuel-Pump-P4070-Electric-12V-4-8-psi-72gph-/252116518319?hash=item3ab350c5af:g:f40AAMXQEgpTD7hV&vxp=mtr
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:08am
Butch it right on with the recommendation for the Carter.  They can run on either +/- ground as they are a two wire pump. I have them on both of the pullers. They can be has from places like JEGS or Summit racing just as cheap and anywhere. Also have you checked into places that rebuild mechanical pumps for older cars? Call me any day before 2PM or come over Saturday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:20am
I found NOS AC Delco fuel pumps on eBay for cheap for my EIII a few years back and picked them up as as spares (and have used them).  Delco number is 8779.   I probably have to go electric myself when my supply runs out, lol.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:34am
Did some looking around on eBay...this looks like it even though it's not listed for it.   Priming handle is different than original but mounting boss looks right and fuel bowl sticks off to the right correctly.   $22.09!   Might have to pick one up myself for another spare.  Good thing is new ones should have diaphragms that work with E10 fuel.   Mike
http://www.ebay.com/itm/4222452M91-Fuel-Lift-Pump-for-Allis-Chalmers-Massey-Ferguson-165-30-3165-65-765-/171997355044?hash=item280bd75c24:g:9kAAAOSwZVhWRRFD
Edited by Skyhighballoon(MO) - 05 Oct 2016 at 10:35am
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 10:42am
Found another one on eBay with free shipping.  Can find it on other web sites too but higher priced.   Mike
http://www.ebay.com/itm/4222452M91-Massey-Ferguson-Perkins-4-203-Fuel-Pump-MF-65-165-1080-1085-9001-/272192115491
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 8:05am
Thanks everyone for the help and advice.  It is greatly appreciated.  I will look into these.  Thanks for researching and providing links for all of these products!
