6060 3 pt hitch won't raise
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6060 3 pt hitch won't raise
    Posted: 04 Oct 2016 at 5:50pm
Got a 6060 that the 3pt hitch will not raise, cables all good, just no response at all from the lever,, any help appreciated
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 8:43pm
Try moving the traction booster lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 9:25pm
There is a plug on valve body under your seat. Remove plug, under plug is a valve that must seat to lift. Remove this valve and check for any thing under valve keeping it from seating.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 4:03am
Traction booster lever is froze hasn't moved in years, thanks Mack I'll try that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 6:24am
If the Traction Booster lever is frozen and hasn't moved in years, I sure hope it's all the way to the rear. Both levers have to be rearward for the hitch to raise.
