speaker size in 7000 cabs
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: speaker size in 7000 cabs
    Posted: 04 Oct 2016 at 3:03pm
just curious if anyone knows off the top of there head what size speakers fit in the cab on 7000 series. are they 4"? or 5"? i want to order a set to be ready to go in when i remove the roof. also has anyone cut out the stereo opening to accept new style car stereos?i put a chepo ebay radio in it last time that fit the old style mount it lasted about a week. id like to try a "marine" radio this time. pyle has one thats pretty cheap. i figure a marine radio may hold up better
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 5:11pm
Watch the depth buddy cut one out then like to never found one short enough to fit
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 5:13pm
I had these 4" speakers (not currently available but I am sure there are many like them that are) put in and this radio. It has worked great in my 7060 for about a year so far. There was cutting involved for the receiver and it is not flush, it sticks out of the console about 2".
If the Pyle you are looking at is the same as the one I saw a while back the reviews I saw say don't bother it is junk.
https://www.amazon.com/gp/product/B006LTTANC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00SAY83J8/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Edited by Ben (MI) - 04 Oct 2016 at 5:15pm
Part time farming with a 1980 7060 and 1984 F3 hydro.
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 7:26pm
I just did a full sound system update to our 7050 this summer.  Pioneer deck plus 5 1/4" front speakers! Big smile
The full size decks fit just fine once the mounting hole is cut out but it will need to offset up just a bit though so the bottom of the deck lays where the bottom the original face sat.
I cut out the old speaker holes to fit 5 1/4" speakers as well and could have went larger and fit 5 x 7's  too.   I haven't got around to it yet but I plan to add pair of boxed 6"s or 8"s behind the seat some day so I pulled the wires for them down when everything was apart.
Two things need to be done to add newer digital deck though.  One is you will need to pull a 12 volt live wire in from the battery being there is no decent constant live wire up there to tie into that can support the power requirements the new decks take and second, more than likely the old foam cab heat and AC liner up there is junk too so plan to replace that as well.
I just put a new piece of 1 1/2" foam in that covered the whole roof cavity which greatly improved the blower airflow and noise plus made a substantial improvement in the speaker sound quality being the speakers were no longer mounted in an acoustically undampened metal box plus it added ceiling sound dampening and thermal insulation as well.
As for getting wiring up there, the main cab frame has is open from the roof down to just above the rear axle on the left so pulling a live power wire and optional rear speaker lines through that is dead easy too.  I tied into the main battery power with a 20 amp circuit breaker on the new live line.
Lsst, while you're up there go nuts with the air hose and clean your heat and AC  cores  along with everything else out.   Ours could have grown potatoes in the dirt up there.  LOL
Also if you do much night work while you're at it it would easy to add an extra power lead going up to the roof that could run some cab mounted lights off a relay that is activated by the main lighting circuit as well being those two little light on the front  half way up the sides of the cab are darn near useless by themselves.  Wink
Edited by Tcmtech - 04 Oct 2016 at 7:42pm
This page was generated in 0.077 seconds.
