What is it??
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Topic: What is it??
    Posted: 04 Oct 2016 at 9:48am
I also got this unit at the same estate auction. To me (from my Google Searches) it looks similar to a Fertilizer Side Dresser for an Allis Chalmers G tractor, but it doesn't look exactly like the ones I've seen in pictures. Please chime in with any information you may have.
Thanks!
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 11:59am
Corn planter parts
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 2:20pm
two row snap couple corn planter fertilizer.
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:33am
what makes you think it is a snap couple?
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:51am
early style boxes
nonetheless ,still dead.
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 11:55am
Gary Burnett,
What about this unit? Would this fit that planter or is is a seperate unit? Is it complete?
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 12:45pm
Gate style bases should work on planter
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 1:33pm
Originally posted by rtr rtr wrote:
Gary Burnett,
Like Fred said its the early style  hopper,from looking at the picture of the G with the 2 row mounted planter there isn't enough room for fertilizer hoppers and drive.There appears to be several different fertilizer distributor and planter options that were offered for the G going by the books I have.
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 1:54pm
Ok. So I'm guessing that the fertilizer unit isn't part of that planter. Does it even fit a G or does it fit something else?
The ones I have seen on a G in pictures on the internet show a 2 row fertilizer. This one only has 1 hopper.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:14pm
It looks like the side dressing attachment for a G.
You would use it with the cultivators to apply fertilizer.
The is a sprocket the mounts onto the rear wheel to drive it via a chain to the small sprocket on the attachment. There is a rod the attaches to the cultivators and the clutch that is next to the small sprocket. This would stop the fertilizer when the cultivators are raised at the end of the row. Both items that you bought are 'GOOD FINDS'.
Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:21pm
Thank you!! If I recall there was another planter there missing the hoppers that went for $10. I should have gotten it too but figured I bought enough. What would you say the fertilizer attachment is worth complete and working......and what is it worth in parts as it sits now. ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 9:24pm
I have seen the planters go for in the $500.00 range.
The chain is fairly common and the sprockets show up on ebay from time to time.
The side dresser might be worth a $100. or more.
Bob
Edited by Chalmersbob - 05 Oct 2016 at 9:25pm
rtr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 8:08am
Bob
Bob,
What about the planter and the side dresser restored and working? What would they be "worth" then? a range is fine.
This page was generated in 0.083 seconds.
