Opinions |
DanD
Topic: OpinionsPosted: 02 Oct 2016 at 6:06pm |
I was just thinking the other day about the two 185's my dad has had. The older one had a manifold heater as a starting aid. The other has ether. Which one works better? What do most people prefer? I can see how the heater would be questionable if the batteries were already a little low. I was just looking at the picture I took of the 6070 I took at the Fanetti auction open house. I see it has both. I though they usually only had one or the other for obvious reasons!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 02 Oct 2016 at 6:25pm |
My 6080 has both the manifold heater and factory ether injector. The warning label in the cab says not to use both at the same time (for obvious reason). I do like the manifold heaters - they work well as long your battery is up to snuff. Only when it isn't do I use the ether.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 02 Oct 2016 at 7:09pm |
Either is bad... it works but too much and you get to take your motor apart and rebuild it... The manifold heaters work good but I like a block heater if it gets really cool they hear the oil and the motor will turn over easier and there is less stress on the motor as it is physically warm.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 02 Oct 2016 at 9:18pm |
I have both on my tractors, and the first day they came home, the cans got removed. then I bought the 7010 new, it also had both. and one day my dad climbed in it, I hadn't taken the can out of it yet....until dad came over to me and said the tractor sounded funny! I went to check and he had kept hitting the what he thought was the start button
and filled the manifold with juice. then hit the start button, and blew that manifold off in about 8 pieces. that can got removed that day!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54699 |
Posted: 02 Oct 2016 at 9:26pm |
I hadda D-19 that had the air horn pre heater, from the factory. All it lacked was the second solenoid, and the wire. It was my grandfather's tractor, and he believed in ether. He had a ether can installed on it, as long as he owned it. Hadda rebuild it a coupla times, as the tractor was a junkie, and knew how to press its own ether button. Every time I checked, that can was empty, or half empty, and flat, dead, devoid of propellant. I took it off, hooked up the AH heater, and was surprised how well 2 minutes of preheating started the tractor. Also was surprised at how quick it would drain the batteries, on a cold day. As a Backup, I installed a coffee pot style coolant heater. there wasn't a day cold enough in 15 years, here in MD, that that coffee pot heater wouldn't start it, after a half hour or 45 minutes...
DanD
Posted: 02 Oct 2016 at 10:07pm |
I was just curious what everyone thought. Of course it goes without saying that an hour or two with the block heater plugged in is by far the best and is sufficient by itself. But sometimes something comes up quickly. Both my dads 185 and the F3 combine have ether (and block heaters) so the can of ether literally lasts for years but I guess a quick push of the ether button occasionally while cranking the engine doesn't seem to have hurt anythng yet. I know about 35 years ago my grandfather also committed the aforementioned confusion between the ether and starter button but they just let it sit for a while to let the ether evaporate some and hopefully waft out of intake manifold. Didn't seem to hurt anything.
Dan73
Posted: 02 Oct 2016 at 10:10pm |
It is easy to get too much ether in the motor. If it explodes too early in the compression stroke it will bend the rods. I have used ether but I avoid it as much as I can. I still call it rod bender in a can.
DanD
Posted: 02 Oct 2016 at 10:43pm |
But I do believe that the factory injection systems only inject a tiny amount of ether and if you wait to inject until you see white smoke coming from the exhaust, it seems to work ok. On the other hand, I've seen some morons spray a 10 second blast of either right into an air intake. I stood back quite a distance from that situation. |
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 03 Oct 2016 at 1:06am |
Both systems work if used correctly, Dad told of when he worked at the Allis dealership in the 60's when the 190 XT's were new and one mechanic using only the manifold heater was able to start a new 190 XT diesel at -10. The first thing he did on his 190 was take the power wire for the ether injector button off the keyed power and put it on the solenoid side of the starter button, and disconnected the wire from the solenoid to the heater. This prevents the problem Shameless had with an operator pressing the starting aid button thinking it was the starter, then finding the correct button with consequences. I use the heater on my D21 and WD45 diesel, and on the 190 XT III diesel, D17D, 7050, and R50 they use ether (automatic on the R50). I know some people are dead set against ether, but I plug my equipment in when it is winter time, and the ether is only used on the cool mornings (40-55 degree) when the tractor needs just a little encouragement to get going.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24889 |
Posted: 03 Oct 2016 at 6:06am |
Had to chime in here... as some know I have a 'rare, ultra low compression - extra blowby' Buda diesel engine in my A-C forklift.
The single glowplug in the intake does work but can't heat enough air, hot enough to get engine to start,even with 2 batteries. 2-3 seconds of ether and she fires up nice. Sure, in the 'real' world, I'd have the engine totally rebuilt(sleeves/pistons/head/FI pump) but I ain't got an 'extra' 5K in my pockets....and ether cans are cheap.. I was going to replace with Cockshutt gas engne but step 2 was 'remove 4000# counter weight'....sigh..sold Cockshutt. If I used it more in the dead of winter I would have an inline block water heater as well as a battery heater and an battery maintainer. A warm engine IS a happy engine! Easy to start and ready to go sooner. Jay |
DanD
Posted: 03 Oct 2016 at 3:32pm |
Having the ether system powered from the starting circuit is something they should have done from the factory. Wonder why they didn't do it. |
Dan73
Posted: 03 Oct 2016 at 3:41pm |
I think the ether systems where a dealer add on back then or atleast it was on the ih 986 we has. If they where dealer added it would explain why they would be wired however the dealer thought was right not designed in by an engineer.
Hockeygoon
Joined: 13 Sep 2016 Location: Manhattan, KS Points: 1210 |
Posted: 03 Oct 2016 at 4:05pm |
We used either on an 886 with the German diesel with everyone from my dad to 12 year old boys running it. It ran just over 9000 hours when it was overhauled the first time, the engine was actually in pretty good shape considering in the dead of winter it was getting started as the primary "chore" tractor for everything from feeding silage and hay to running the grinder mixer.
When it was overhauled the second time it been run right up to 10,000 hours - the engine was in horrible condition with broken rings on every piston. It had gotten to where it needed either to start no matter the temperature. It was traded after it had run 5000 hours on the second overhaul. |
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 03 Oct 2016 at 6:58pm |
Just gotta be careful with it. Definitely not a more is better scenario...
DiyDave
Posted: 03 Oct 2016 at 8:50pm |
A little interesting fact:
A perfection 500 wick kerosene heater slides right under a D-series oil pan, and will heat it up to operating temperature, in about 45 minutes, in some very cold weather. And it don't need no 'lectricity to do it... I learnt this little tidbit, during the winter of 1977, when the Chesapeake bay froze over for over a week. Our power was out, and I needed to plow snow out of the driveway...
![]() Edited by DiyDave - 03 Oct 2016 at 8:52pm |
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 03 Oct 2016 at 10:28pm |
We have a 185 sitting in the shed, that got here in 1976, has never been apart, and has its fair share of either sprayed in it over the last 40 years. I would rather give it a little shot of either, then hold the heater on, and drain more battery, then it won't crank fast enough to start it. Then you can't use either. So I usually just give it a snort. And it's off, when it's cold. Jump pack and a can of either if starting a ,cold AC will save you lots of trips back and forth to the shop.
shameless (ne)
Posted: 03 Oct 2016 at 11:28pm |
I don't use my tractors as much in the winter time as I used to, but if I do need one, I have a switch in the house that is dedicated to an outlet outside in a shed. and when I get up in the morning, I can switch that on for the heater on the tractor that is already plugged in outside. and then after breakfast or later in the morning I can go out and start the tractor with no problems. with a 1500 watt it don't take long to heat up an engine. or you can turn it on when you go to bed. it's just set up that way so it doesn't hafta run all day and all night.
Dan73
Posted: 03 Oct 2016 at 11:58pm |
Yup Shameless that is the best solution to starting a diesel in cold weather.
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Posted: 04 Oct 2016 at 6:18am |
We try not to use either. On the newer 6080's and 8050/8070 we will not use it at all. Just plug them in. Both 6080's will start down to 20 degrees. I plug them in after that. We do however have an F2 and L2 combines that are addicted. They won't start below 80 without a little shot of either. But I just give them a 1 second blast in the air intake and by the time I get back to the cab they usually pop right off. They run good other than that. Dad calls either compression in a can. If the engine gets a little weak just add a little compression.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 04 Oct 2016 at 6:29am |
20 degrees is a October or April morning here, about 5 miles from Canada.
30 below is cold, but something we see a couple days almost every winter. In very cold weather, there is no substitute for a block heater, but either the manifold heater (especially in conjunction with a battery charger on cold mornings) or ether works, if used properly. |
WD45Diesel57
Joined: 20 Jul 2010 Location: Varna, Ont. Can Points: 646 |
Posted: 04 Oct 2016 at 7:25am |
my 7020 starts great with the pre heat, but my d17 needs a tiny little sniff of ether while cranking to fire up on a cool morning
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
