allis 8030 tractor hydraulic problem |
arty
Topic: allis 8030 tractor hydraulic problemPosted: 01 Oct 2016 at 4:57pm |
was harvesting corn and suddenly lost all hydraulics, no steering, no transmission, no remotes
. oil levels ok. changed all filters, still no hyd.
left tractor off for half hour, all hyd. worked, tractor moved a short distance and lost all hyd. left over night, had hyd. for about 10 minutes, lost hyd. I'm baffled!!!!! any ideas?
tornado8070
Posted: 01 Oct 2016 at 5:00pm |
Your torque limiter needs to be replaced. Needs to be split but not the worst thing to happen....
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
DrAllis
Posted: 01 Oct 2016 at 5:40pm |
Unfortunately, a torque limiter doesn't fix itself. This post is quite confusing and needs questions answered accurately to come up with a solution to the problem. You said you changed all the filters??????? Exactly, which filters did you change and did the problem exist before you changed the filters. Where are you checking your oil levels?? There are TWO PLACES for oil on an 8030.
arty
Posted: 02 Oct 2016 at 8:32am |
Thanks for responding. oil levels in both chambers are checked regularly. problem started before all three filters were replaced.
DrAllis
Posted: 02 Oct 2016 at 9:00am |
And how does the tractor act this morning?? Does your 1800 RPM transmission light work??
arty
Posted: 02 Oct 2016 at 2:10pm |
yes transmistion
light works . when tractor stops moving trans. light comes on.
DrAllis
Posted: 02 Oct 2016 at 7:10pm |
I think I'd add 2 gallons of oil down the tube with the long dipstick in it just to see what happens.
