52 WD not starting.
jarrod318 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Topic: 52 WD not starting.
    Posted: 29 Sep 2016 at 12:24pm
Hello guys - I need help again. Started the tractor yesterday after it had sat for 2-3 days. It started up and moved about 40 feet before it quit. I tried to restart and heard a sizzle or zap sound.
I checked the battery (12V) and its fine. The battery cable terminals were bad so I replaced those and still no Bang. Had some issues with the starter in the spring, I had it rebuilt last year and again this spring.
So, I don't know where to start. I was thinking that I could use my volt meter so see if power is getting to the starter? I cleaned the contact with sand paper.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 12:33pm
Yes verify you have juice at the start switch. I would also remove the starter and pointed bolt that holds it in place and make sure they have a good electrical connection with the frame. A nice painted starter where it contacts the frame is not good.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 12:46pm
Thanks Stan.
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 1:16pm
i see you replaced the cable ends but did you wire brush the battery terminals? sounds like you still have a bad connection. or the starter switch is bad
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2016 at 7:54pm
So an update. I have power at the starter. I took the starter switch off to clean it up and that didn't help.
I then decided to pull the starter and it did feel like it was a little loose. I put it back in and it fired up, ran for a minute and died. When I tried starting it again it made a grinding sound and won't start again?? Where do I go from here?
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 6:57am
Grinding noise? Sounds like starter to me....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 7:21am
Sounds like two problems to me. It quitting on you sounds like a fuel problem. I had a stuck float one time that it would run just long enough to get it out of the barn then die. I pulled the carb drain plug at that point and nothing came out until I smacked the side of the carb with a screwdriver and then gas flowed. Did it a couple of times to me before I pulled the carb and cleaned it good. I also thing something is wrong with that starter. spring on bendix may be broken and also check to be sure you have the starter fully inserted in the clutch housing so it will fully engage the ring gear on the flywheel.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 6:24am
I'd agree with that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 6:48am
Unless you have a coil and distributor, and a short in your wiring that sucks enough juice from the battery to kill the spark, the dying has nothing to do with the not starting.
 2 different problems. The sizzle is a poor connection somewhere. I have had a battery post develop a dark oxide looking coating that insulated the battery from the clamp. GOTTA be shiny clean.
 Did you turn the gas on before you drove the 40 feet? Big smile What do you have for ignition? Mag or distributor?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 7:17am
If your starter is still a 6 volt starter it will grind sometimes due to the higher rpm that 12v will spin it, and it will occasionally stick when engaged, just put in 4th and rock the back tire and it should pop back out.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2016 at 12:13pm
I'll +1 for the folder labeled: 'there's more than one problem here'.
For the benefit of all here, please clarify:
When you say it doesn't start, that suggests to us that you're having no difficulty getting it to crank over, it's just that it won't ignite a mixture.
But your explanation sounds more like it's not CRANKING.
Divide and conquer:
First, make the starting circuit and motor crank the engine over properly. Starter circuit- battery, cables, starter switch, starter, ground path through block, to ground cable, back to battery. Pull the switch rod, it should crank.
Next: Get ignition... switch on, crank it over slowly by hand... if you don't have spark at the coil, troubleshoot points circuit.
Once you have that, test to see if you have spark while cranking WITH the starter motor. If you have spark when turning by hand, that's one thing, if you LOSE it when using the starter motor, you still have a wiring issue.
Once you have spark while cranking with starter, troubleshoot fuel, compression, and timing.
