Straw Walker Blocks - lubricant recommendation?
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Topic: Straw Walker Blocks - lubricant recommendation?
    Posted: 26 Sep 2016 at 9:48am
I'm putting a set of new (oiled wood) straw walker blocks in an F3. Does anyone have a recommendation for any additional lubricant that I should put on them before installation? I was thinking either motor oil or some planter graphite, but maybe I should just install them "dry"?
Any suggestions?
Thank you!
Peter
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 10:08am
lard, beef tallow works really good on walker blocks.
remember plunder than burn
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 12:34pm
Do you not have to lube them occasionally after installation, if you're lubing them now?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 12:36pm
I think they're intended to run without lubrication, but was just looking for something to put on them from the start. Beef tallow/lard seems like a good idea.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 9:50pm
I think they develop a polish once you run them and that should make them maintenance free.
We never oiled ours, but we keep it in the shed.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 8:44am
I have seen some with a grease zerk mounted in the blocks. when I put new ones on I always just slimed a little with my finger on the inside...just a film of grease
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 8:45am
make sure when you tighten the bolts, that the blocks are not tight on the crank, you'll break the chain. you may hafta put a few paper bushings in them.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 8:46am
They should turn over by hand.
Wink
I am a Russian Bot
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 11:25am
I use STP oil treatment. The really thick stuff in the blue bottle.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
1terrygladys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 5:56pm
The shaft augers on our old combine used to get to rattling in the blocks.  I squirted silicone spray lubricant between the blocks and shafts.  Quieted them right down.
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
