3pt hitch
Tilbury View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tilbury Quote  Post ReplyReply Direct Link To This Post Topic: 3pt hitch
    Posted: 24 Sep 2016 at 6:18pm
My 3pt hitch on d19 will not hold in position. It goes up and down fine but when you try to hold it in position it slowly creeps up to top and holds there
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:36pm
check your draft control lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tilbury Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:42pm
Ok will do thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tilbury Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 10:40am
This tractor has 4 position control for 3 pt hitch. Up, down, hold position and traction boost. In hold position or traction boost position it slowly creeps up to top of 3 pt hitch position with nothing connected to 3 pt hitch
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 3:18pm
We had the same problem. There was a messed up ball and spring in the valve block that the levers are on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tilbury Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 5:09pm
I had the valve block off did not see anything wrong do you remember if it was the poppet valve or what u did to repair it
This page was generated in 0.172 seconds.
