7060 radiator
chalmers200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chalmers200 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 radiator
    Posted: 24 Sep 2016 at 3:16pm
I need a radiator for my 7060.
Thanks
jeffmckinney7060@yahoo.com
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 3:43pm
will one outta a 7080 be the same? I have a good one of those!
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 4:51pm
Have a never used recored one for 7030. Located in southern mi near state line.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:00pm
Cost less to have my 7045 recored with warranty than getting a "good" used one with no warranty plus truck freight.
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:12pm
What does a recore cost roughly? My 7050 has a leaky radiator. Shameless if chalmers200 doesn't want your radiator I might be interested, does it have the built in oil cooler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:34pm
I paid $800. But like I said, it was local and less than other places I could find. This guy has been around 40 years as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 8:35pm
I don't know Grinder...built into the radiator, or mounted in front of it?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 9:07pm
If you want a rad that you will never have to touch again, get your old one recored.  If you want to replace one next year (give or take), get a used one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 10:00pm
built in,2 hoses screw onto the bottom tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 2:12am
i'll look
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 9:05pm
7080 radiator is taller than the 7060, need a different fan shroud (I have one if you need it), and an offset lower radiator hose to come up to the block (just need the 7080 lower hose).  The 7060 I had needed a radiator, ended up getting a correct one for a 7060 and found out someone else put a 7080 radiator in it before.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2016 at 11:22pm
Have a 7060 radiator for sale, would sell only after having it checked at a radiator shop
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 7:12am
I would definitely go with a recore. I had my 7045 done a few years ago, I think also around $800. Then all the "good stuff" is new.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 11:56pm
It cost me around $1,300 for a new one for my 8030 a couple years ago.  I believe they used the upper and lower tanks from the old one.
Allis Express participant
