80r mower belt
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: 80r mower belt
    Posted: 24 Sep 2016 at 2:36pm
I broke the belt on my mower. Agco part number on belt is 70804201 this crosses over to a c103 belt (7/8 x 107). I ordered a c103 belt but it is too loose. Has anyone had this problem before and what size belt did you use.
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 3:44pm
if you have a belt idler pulley, replace it with a larger one!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 6:44pm
Never had a problem with the C103 belts I have installed on 80R mowers.
Are your pulleys worn out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 6:51pm
I've found that different belt maker companies belts aren't always the same! even tho they say they are! (maybe they use china made measures too)? lol
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 7:02pm
Think I was using C102 belts on my 80R mowers
