LEDs |
AllisandGleaner
Topic: LEDsPosted: 22 Sep 2016 at 8:08pm |
Where is the place to buy led lights for tractors at? For the cheapest.
Edited by AllisandGleaner - 22 Sep 2016 at 8:08pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89166 |
Posted: 22 Sep 2016 at 8:12pm |
I have been looking on e-bay at several different types, rectangular case... 18 watts or 24 watts ..... say they fit 4 wheelers / tractors / dune buggys.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 22 Sep 2016 at 9:06pm |
Northern tool has some decent prices.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 22 Sep 2016 at 9:09pm |
I got a 12" "Cree" combination spot/flood light bar for $20 on Ebay. I'm very satisfied with it.
steve(ill)
Posted: 22 Sep 2016 at 9:16pm |
On another note, I bought a 12 volt LED bulb at Menards that looks like a 60 watt Incandescent bulb. Round with a screw base. I wanted "light" out in the middle of a field that had no electricity. This bulb was 10 watts, but equivilant to a 60 watt bulb that you use in the house. I mounted the bulb in a socket with a switch and a garden tractor size battery that was rated at 18 amphours.... that is one amp per hour for 18 hours... the 10 watt bulb pull less than 1 amp so it would run 18 hours theoretically.... It worked great for a remote lite for several hours out in the field and the light shines 360 degrees.. cost of bulb was about $8.
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 22 Sep 2016 at 9:28pm |
wally world or HF
JPG AUSTRALIA
like steve said ,ebay is the cheapest,i bought some back in march,i got 8 square 27watt ones for $60 dollars inc freight ,so $6 each.They have done a lot of hours on the sprayer and other tractors with no probs.Also bought a lightbar of the same company which was a cree type with combined flood and spot ,36 inch was about $80 worked great but got moisture in it over seeding and they replaced it for me,no worries.
shameless (ne)
Posted: 22 Sep 2016 at 9:29pm |
also Canada supply
John D
Joined: 12 Sep 2009 Location: Sherman, IL Points: 360 |
Posted: 23 Sep 2016 at 7:50am |
We have bought ours on Amazon, Larsen Lights, Worthington Ag Parts, and a private reseller. All work just fine but I imagine the one's from Larsen and Worthington are better quality? Hard to say so far.
1964 D17 series 3
bigredisb
Joined: 16 Aug 2016 Location: Racine WI Points: 185 |
Posted: 23 Sep 2016 at 7:57am |
I have been getting some takeoff JW Speaker ones that are very nice. Even used they aren't cheap but they will last forever.
On another note about LED's I have been told that you need to keep some regular lights to create enough load to get the generator to excite and charge. I am not sure if that is a urban legend or not. |
1961 Allis-Chalmers D15
1949 Farmall Super A |
steve(ill)
Posted: 23 Sep 2016 at 8:06am |
alternator/ generator looks at the battery condition and gets excitation from it....... You can run any lights or no lights, and the battery will still charge.
Dan73
Posted: 23 Sep 2016 at 8:31am |
It can be a load issue with some switches because if the switch doesn't have good clean contacts the led lights might not draw enough current to work but you should get a new switch in that case. I think things like that make people think it is a problem for everything else.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34430 |
Posted: 23 Sep 2016 at 10:02am |
What Steve(Ill) is refering to is actually not the gen or alternator, its in the turn signals... where your replacing them with LED.. they do not have enough draw to make the signal stat work so you have to put in a resistor or keep a bulb or two in the system to load it enough to work correctly.
Yea, Ebay seems to have some cheap units, there was a thread onhere a while back about them. Heres the one link from awhile back to the thread on LED lighting... http://allischalmers.com/forum/forum_posts.asp?TID=123879&KW=LED+lights&PID=1026743&title=tractor-lighting#1026743 |
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
wekracer
Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
Dirty contacts cause problems with large loads. It will begin to arc and heat up. If it makes contact enough to complete the circuit the lights will come on no matter the amp load. Larger loads will test bad connections.
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 23 Sep 2016 at 10:35am |
They also make a flasher for LED lihgts
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1867 |
Posted: 23 Sep 2016 at 1:09pm |
here are 2 links to threads I started, the 8050 has amazon lights in the bumper, the r50 has better buyer's brand lights i bought at work. currently working on pricing 1600lumen floods here at work that I will be able to buy at our cost ($18/light.....)
http://www.allischalmers.com/forum/forum_posts.asp?TID=112770 http://www.allischalmers.com/forum/forum_posts.asp?TID=127377
DanC911
Posted: 23 Sep 2016 at 1:20pm |
I have had great luck with http://www.superbrightleds.com and Amazon
