Shameless
Mark D. View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Topic: Shameless
    Posted: 22 Sep 2016 at 8:03pm
Please check your PM inbox.  One more oops and we are out of straw walker cranks on our Gleaner G's.  Thanks!
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller
Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 9:27pm
my PM box is empty for some reason...try again! I was just in there and there was just 2 messages...PffffT! and I was saving other messages cuz someone's needed some parts...
how come yer having "oops"? what are you doing to them?
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 9:39pm
Quit replacing till you figure out why they are breaking. :)
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 9:44pm
Just convert it to a rotary! No more walker cranks! Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 12:32am
are your blocks worn? that will will break them up!
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark D. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 7:34am
Shameless,
Call my dad at 989-574-8301.
Clipping some weedy dry beans so far this year.  First time the straw chopper couldnt keep up and weeds/beans wrapped around it plugging up the whole rear before my uncle noticed and stopped.  Of course bending cranks.
Put it back together, this time the straw chopper was spinning free and clear but the beans(this time less weeds) failed to fall down into the chopper wadding up above the chopper which plugged the whole rear before my uncle noticed again.
Honestly, a bit puzzled.  We have 3 of these combines working and each of them technically run a bit different adjustments back there.  We didnt change anything back there for this year but all a sudden got these issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 9:54am
so I take it you don't have the little tattle tale back there that tells you when you are plugged up? what size header are you using? I can't imagine plugging up a "G" combine as wide as they are and their capacity! and it takes ALOT to bend one of those cranks!
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 1:00pm
For some reason G's will do this. My dad and I piled one up straight cutting, there was very large kochia plants sporadically in the  field, very green. No lever monitor in the back end. By the time I said there is nothing coming out the back, too late, BANG. It was packed tight like a bale, it ripped the drive shaft right out of the side of the frame. Took two days to fix, a neighbor dropped by to visit, he stayed the whole two days and helped us enormously, his name is Bill Gilmour, he still farms. Even my 90 year old grandpa was helping, he was cutting the paper shims for the blocks...Bent the cranks bad, had a very hard time cleaning the back out. We put a paddle monitor in the back after that. I'm sure you could still find one and rig it up. Trev.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 1:15pm
If the chopper knives are worn out it will do this. It will not pull trash into chopper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 4:09pm
Mark....i'll call yer dad, it's raining outside today, i'll call him when I can be outside by the combine
This page was generated in 0.123 seconds.
