Oh dear, no Deere....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Oh dear, no Deere....
    Posted: 21 Sep 2016 at 8:39pm
Sold both of my Deeres today...seems to be the way to make money with them
ALLIS EXPRESS!
This year:
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:40pm
The new generation tractor was probably the workhorse of the two!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:46pm
Sure was a dog compared to the Perkins in the 175D! The 5525 was nice, too nice LOL!
ALLIS EXPRESS!
This year:
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:47pm
You are probably right people pay good money for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:52pm
What did you get for the 3010?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:52pm
We have a 2008 5525.
It's a nice tractor with 109 hours (Looks almost new, and the bar codes are still on the tire tread. I'm hoping one day in about 35 years it will bring some good money, since we never use it), except the 3pt lift is screwy. There's a speed adjust knob that does nothing. It raises super slow, sometimes takes 10 seconds to raise. Sometimes it does nothing and you have to move the 3pt knob up and down a few times. Then it still goes super slow. And...when you lower it...sometimes you can move the knob all the way down, and nothing happens. Same as before, it you move it back and forth, it will go down, but when it does, it drops like it lost all hydraulic pressure! I conducted all these tests with a roto-tiller on the back too, so it wasn't empty load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:57pm
Sounds like something is plugging up that speed control valve. If this was an older tractor I would suspect someone spliced a line and got a metal filing stuck in it. I would take the valve apart and see if you find anything in it. Or sell the tractor to someone who doesn't use the 3 point....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:00pm
Did you flip that little cover up and adjust the knobs? I didn't even know they were under their until I studied the manual as there are two different styles. On this one you have to hit the UP toggle to activate the 3pt after startup, then hit the Down part of the toggle. After that the slide control works fine. Not sure if that is the way it is supposed to work, but it works that way on this one. All this electrical crap could be a nightmare! Good news is you have one of the last tractors before the emissions crap was mandatory.....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:03pm
$9k, and I still have the front weights. It's going to Oregon...
ALLIS EXPRESS!
This year:
Morgan in AR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morgan in AR Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:03pm
I have a 3010. All smoke and noise!
Edited by Morgan in AR - 21 Sep 2016 at 9:04pm
If we loose freedom here there is no place left to escape to. This is the last stand on earth. -Ronald Reagan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:18pm
Yep, those are the knobs I was talking about. One is supposed to control the speed I think. I tried adjusting both of them every which way, and nothing much happens.
Where is the up/down toggle switch you speak of?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 9:46pm
It is on the thumb side of the slide control...up has a dimple in it, down doesn't. It is the one touch up, one touch down switch....kinda handy actually....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:07pm
So one touch raises all the way up, and one touch lowers it? I know what switch you're talking about, but I never tried it.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:22pm
Eldon is buying the Miller!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:27pm
Yup! Just make sure your down speed isn't dialed all the way up or your tiller will make a dimple in the ground
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:27pm
PBR!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (1) Thanks(1)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:39pm
Guess I need to do some more experimenting! Thanks for the tips!
Post Options Post Options   Thanks (1) Thanks(1)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:57pm
that's good too Eldon!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 10:58pm
and i'll bet yer old........oooops...I mean yer wife has a place to put all that $$$$ already huh?
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 11:09pm
Creston-the 3pt doesn't work, off to the tree line for that one.
Maybe it can pull the pumpkin wagon at the fall harvest festival.
JD used to sell farmers brand new antique tractors, now they sell brand new lawn ornament tractors.
If the 3pt is screwy, stand clear as you know, dangerous. Ask the JD dealer what them buttons are for. The manual is online for free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 11:11pm
good descriptions Brian!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 11:16pm
I don't know what's wrong with it. It used to work fine, then it doesn't. It's been barn kept, and is like-new. Never needed worked on, except for regular maintenance.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 1:10am
I figured once you sobered up and realized what you had done those Deere's would be
gone.Might as well go on over to YT and take your medicine we're waiting for you(LOL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 3:09am
So it has 109 hours has a broken 3 point hitch and has had needed regular mantance to reach that record number of hours... can't see why anyone wouldn't want a Deere....
Actually the thing that hit me was barn kept. Have you had any trouble with mice? Critters love to chew on wires and modern tractors have tons of wires for them. Wondering if maybe sitting for so long in a barn something moved in and made your deere home.
Edited by Dan73 - 22 Sep 2016 at 3:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 3:35am
anything won't need anything fixed on it if ya don't use it! and if you don't use it, why keep it? sell it and buy something you'll use! (like orange stuff?) just a shed space hog right now! Dan....go down there and SLAP that boy! me thunks Rachel and me need to talk!
JD Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD Dan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 3:40am
Didn't there used to be a 520 and 4020lp also?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 7:55am
Eldon, you sold that 3010 for a lot more ears of corn than you paid for it, eh?LOL Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 7:59am
It's not MY tractor! That's why it's here!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 8:03am
Well I say regular maintenance, it's had an oil change and a battery or two.
Nope, no mice! I've already checked wires and everything, and nothing looks like it has been touched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2016 at 8:28am
Yup, pretty good return on a half pound of seed....
ALLIS EXPRESS!
This year:
