Muffler vs no muffler?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Muffler vs no muffler?
    Posted: 19 Sep 2016 at 7:48pm
I hope this doesn't start another debate like the B oil filter post, but I've heard some people say that tractors with straight pipes develop more horsepower than those that have mufflers. Is there any truth to this?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:54pm
They make more deaf operators....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:58pm
I've heard people say that a properly tuned engine won't run as good without a muffler because it needs the back pressure.
Mostly with these kind of statements, you have to consider the source!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:00pm
I doubt you'd notice the difference one way or another. Listen to what Dan said. Your hearing is going to diminish as you get older. Don't make matters worse.
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:05pm
Depends on how restrictive the actual muffler is.
If it's loose and the tractor tries to push it up and off when under a heavy load it's too restrictive and is costing you a bit of power due to back pressure.
If not, a straight pipe is just for showing off and to make you deaf later.  Wink
Personally I like a quiet muffler unless it's a diesel with a good sound proof cab!   Then it can bark and beller all it wants.
Infact one of the neighbors is working his field right now with a big gleaner and compared to how he sounded earlier today I am thinking he might  have blown his muffler out.  He really go got a defined bark going now.
I can even hear when he slugs it and it pulls down hard even though he's a good mile or more out!   Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:09pm
A Saab which breaks the exaust before the cat will not run for crap. I was stuck on the side of the road one night with that problem.   Ended up taking wire and making a hanger off the heat shield to hold the pipe close enough to the cat to get some back pressure and it ran. I expect this is where the story that a motor needs back pressure comes from but the old motors are not as sensitive as the modern motors. I would expect that the mulfer or lack of one on an old tractor only effects the noise to any measurable amount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:11pm
Use straight pipes!!! I own stock in hearing aids. lol
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:17pm
This has been debated before. There was even some discussion on tuning a straight pipe by length for maximum performance. One plus for a straight pipe is they are cheaper than a muffler.
Still trying to figure out why a under hood muffler has the outlet pinched down to a fraction of a round pipe outlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:19pm
Ken, I thought it was to shoot the fumes higher?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:44pm
like a fire hose nozzle
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:53pm
I like quiet power. Been around too much noisy power in the early years....my hearing pretty much sucks now."They tried to tell me but I wouldn't listen!" Now when I listen they can't tell me cause l can't hear!!!
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:55pm
I pulled the muffler off a 45 when it was on the dyno one time, there was no change in the dyno reading.
                                             Harold
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:57pm
I like mufflers on my engines, but I was just wondering. I try to protect my hearing whenever I can, because I've been around a lot of folks that can't hear well, and I don't want to end up like that!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 10:01pm
huh? what did you say?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 10:07pm
if you have a turbo, that will take a lot of the noise out of a straight pipe. I just like the sound myself, but every one is different, if I don't like the sound, i'll keep a muffler on it. I still wanna put dual pipes up behind the cab of my big boy truck! and maybe on my flatbed truck too! (should wake up the folks in the campgrounds)! I have both mufflers and straight pipes for all my non turbo'd tractors. that's in case the neighbors start complaining about me out with them at night! some have learned!
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:59am
If the muffler is a decent design and sized correctly, there will be very little to no noticeable gain in HP compared to a straight pipe, usually.  I have a muffler on my 7050 and no plans to remove it, even though I have a cab on the tractor.  I have a straight pipe on my series 2 D21 and it only takes 15-30 minutes of work to have your ears ringing if you don't wear some form of hearing protection.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 3:13am
I was disking one night with the 180D, and saw a Sheriff's car pull up at the end of the field. I stopped and he approached, said the neighbors across the road had called (city bots) and complained of the noise I was making! they couldn't sleep! I smiled and told the deputy that they haven't heard noise YET!!!! he bowed his head a bit and shook it saying....ohhhhh....I knew y0u was gonna say something like that! he left and I went home and put the straight pipe on the 180, and a set of ear muffs I use with the chain saw. and went back to the field! man....the lights all came on in their house and they was peeking out the windows!!!! Sheriff never came back! and I smiled all night long!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 5:26am
As indicated by the various posts already, it's a complicated topic, several components come into play, and "it all depends". Gas, diesel, turbo, valves, tuning.....Ever see a racecar with a muffler on it? But depending on class, they're running 6-8000 RPM, no turbo...An old tractor, 1500 RPM making 25 or 30 HP, if you make a 10% gain, would you feel it?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 5:58am
What's wrong with debate? Anyway it doesn't matter to me as I can't hear very well anyway but I still hear more than I want to hear especially around the house(LOL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 5:59am
Need to get yourself a 1900 Oliver with a Detroit that'll make them appreciate the 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 6:09am
http://nh.craigslist.org/grd/5780632888.html?lang=en&cc=gb
There is an Oliver for you. We had a Detroit in a gmc. The issue was if it wasn't wide open it was a dog. Made a bad truck bear to get moving. Might be ok in a tractor they tend to run wide ope. Anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 6:12am
If you're going to go 'straight', pipe that is, replace the exhaust manifoldat the same time.
'technically'(aka from an engineer's point of view) EACH cylinder should have the same length of pipe to 'balance' the pressures in/on the engine.
I know from a great friend of mine that a properly 'tuned' exhuast WILL help the engine's overall performance.This was on a 327/300 Sb in a 62 Etype BTW.
personally I wear muffs all the time having tinnutis(ringing in the ears' 24/7 is NOT fun and I've been told if/when I go deaf the ringing in the ears will NOT stop !
sigh, growing old sux...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 6:47am
Right on Jay, with the equal length exhaust headers!
Which sux worse? Growing old, or dying young? That seems like the 2 options. I have a coffee cup for you: Life's a b!tch then you die!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 6:56am
You ever hear of the Mile-O-Mo Bird?
It's a bird that sticks his head up his A$$ and you can hear him holler for a Mile-O-Mo!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 7:02am
also when I was running my V-8 Gleaner, the mufflers rusted/burned  out and I was afraid of throwing sparks out in the fields....soooooo....I ran dual straight pipes out of it, elbowed so it shot out the one side. it was quiet in the cab, and quiet on the one side, but would wake up the chickens for about 3-4 miles on the other side! (neighbor said he noticed it)!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 7:22am
The more important question is what motor oil are you using?
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 7:42am
If you do switch to a straight pipe, you need to start running 15w-40 oil. With the muffler restriction removed, everything's flowing a little easier so you need heavier oil to keep bearings properly lubed.
OH!!! and don't forget to open up the orifice on the oil filter stem .003592 to keep the pressure correct.
How was that Stan?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 7:45am
Cute, but what the heck inspired that???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:42am
How was that Stan?
That was excellent Dave.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 3:37pm
shoot my dang eyes can't see the diff between 1/16 and an 1/8th these days so WHAT is  .003592 as a drill bit ?/ I USED to see the diff between #60 and #58,long,long ago when I made my own printed circuit boards......
mind you I WANT to know WHO the idiot was that gave us 5.5mm bolt heads !!! OK I KNOW it's 7/32, sort of cause 11mm is really,really close to 7/16.
Dang STUPID use of metrics....
Jay
