gleaner f wiring
vmlb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmlb Quote  Post ReplyReply Direct Link To This Post Topic: gleaner f wiring
    Posted: 17 Sep 2016 at 11:58pm
rats ate the wiring, and I would like to know where the engine tach sending unit is located. My f or f2 has the chevy engine. thanks
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 1:14am
There is no sending unit, the engine tach runs off the alternator.  There is a black wire that plugs into the back of the alternator and runs up to the tach selector switch in the cab.
Edited by VAfarmboy - 18 Sep 2016 at 1:19am
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 6:05am
after you re-wire it....and it's time to put away for winter, take that panel back off and leave it off all thru storage, they won't chew there again cuz it'll be out in the open
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 11:33am
The sending unit for the engine tach on my K2 w/Chevy engine is on the bell housing of the engine. Yours should be the same.
vmlb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmlb Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2016 at 8:39pm
thanks, will see if I can find it. I'm guessing it comes out of the alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 1:57am
Do you have the service manual?   I have a service manual for a K that shows the wiring diagram for the tachometer circuit.  I think the F is the same.
Coming off the tachometer selector switch you should have
-black wire to the alternator
-black/white wire to the ground speed pickup
-black/blue wire to the cylinder speed pickup
-black/green wire to the fan speed pickup.
-yellow wire to the tachometer
Edited by VAfarmboy - 19 Sep 2016 at 2:31am
This page was generated in 0.625 seconds.
