Engine Overhaul Kits
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Engine Overhaul Kits
    Posted: 15 Sep 2016 at 8:17am
Going to be doing some engines over the winter for projects. Is there any info for reviews on engine kits? I know there is Tisco and Alliance. Are there others? What experience has everyone had. I'm doing a 149 and 160 engines. Any advice or suggestions are welcome. Like to do it right but don't want to spend money on stuff that isn't really necessary. All the machine work has been done on the 149 already. The 160 isn't out of the tractor yet. Would it make more sense to just fine a good running engine for the 160 replacement?
Edited by AJ - 15 Sep 2016 at 8:25am
Can't fix stupid
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:21am
I used Tisco on my 8N. I can't complain.
I've heard on some kits (Not sure what brand), the pistons and sleeves are made of cheap inferior metal, and while they may run fine, when you shut it off, the pistons are heated up and they expand. Then if you hit the starter button right after killing it, nothing will happen because the engine is stuck. Let it cool for a while and it will start again.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:23am
Yea, I don't want that problem.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:28am
AJ - there is PowerMax that is well thought of.   Fred is a dealer.   Mike
http://www.powermaxparts.com/
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:47am
I got real lucky a few years back and bought a big box of 16 McQuay Norris pistons, sleeves, rings and o rings for cheap. Got two sets left.
Quality was excellent.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:49am
We sell and install kits with Richland, Victor, and clevite parts.  I have been installing them for 15 years and very satisfied.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 10:30am
Its not the parts 90% of the time .Its the guy putting it together that has no clue on how to do a total real engine rebuild .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 4:22pm
AJ, I would guess you will look long and hard for a GOOD RUNNING 160 for sale. Just buy a kit and rebuild. I agree with FRED-- quality is the rebuilder normally, not the parts used.
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 5:19pm
I bought my 160 kit from Tony Carbaugh. Quality parts and outstanding service as usual from Tony!
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:02pm
Just incase your wondering what the price range is for doing a engine right. I'm at 3,000 on my WD45 engine build.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 9:20pm
I don't care what anybody says, NOTHING fits like original. Rebuild what you have, that way you know what you've got.
The mechanic always wins.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 9:23pm
I didn't think it would be feasible to try to find a 160 engine. For the amount of money someone would likely want for one you could spend a little more and have a new engine that you built and know 100% what you have.
Can't fix stupid
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 3:05am
Powermax is owned by reliance now. I just ordered a kit from them for my d17 226 gas. The 4 inch oem sleeves aren't produced anymore for that motor. But they do sell a 4 1/8 over bore that still has the same 7.25 to 1 compression ratio. Had it had the correct power crater pistions. You will need to get the crank to a machine shop and find out what bearing it needs after they do any work it needs before you can order your kit. When you order your kit make sure the pistions are power crater or dished is the other description people use for them. Also find out what the correct compression ratio is and don't buy a kit that doesn't state the compression ratio. I do have a d15 with a 160.   When you get it rebuilt it had high compression and will need high octane fuel or it will backfire and diesel when shutoff. I had that problem with mine this summer. But do check the compression before you tare down the motor and check the sleeves and pistions before ordering a kit. My d15 didn't need a full kit just rings and bearing.   My d17 needs a full kit.
This page was generated in 1.225 seconds.
