38 tractor rim coating?
Jonny B 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Topic: 38 tractor rim coating?
    Posted: 14 Sep 2016 at 2:31pm
Here is what I found when I pulled my rear rims. The tires were 1940s -1950s vintage Sebring 45 deg. spade grip. The rim inside was painted the same color as the tractor with no galvanizing inside, it would appear the rims were originally painted and they were original. I know that all rims on all manufactures during this period were galvanized so are they replacements? The size is a true 8 X 24, the new ones appear to be all 10" and the rims have not been off since the early 50s due to the rust inside and the age of the tires. It makes me wonder if they replaced the rims withe tires with Allis replacements or they originally came on the tractor orange?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 3:59pm
FYI
Original rims for Early and Late 1938 Bs came 2 ways Split rims very early and narrow 6" rims made by Firestone for the rest of 1938 and early 1939s, using the clamps pictured in the next post. They were both Galvanized.
Any rim not like these using 3/4 bolts and eccentrics are aftermarket or later AC 4 bump rims with the 5/8 bolts and eccentrics.
Let me remind you again Peotone Jonny if you are really serious about owning a accurately restored Early 1938 B there is one FOR SALE right here in NE Texas. B#751
I'm working on new tubes and tires right now for my original set of the narrow Firestone Rims off my early 39B. Measuring these antique rims with a ruler, tires off, they are exactly 7 inches at their widest point. The bead flanges themselves are wider (thicker) and taller than normal todays rims. Measuring the distance between the bead flanges at the bottom they measure 5 3/8 inches at the most. That is why I called them 6 inch rims without actually measuring them. SO. The Miller tire diagram on how to measure rims shows the rim width size to be inside the bead flange to inside the opposite bead flange. The bottom of the flange what Miller labels bead seat is what I measure at just 5 3/8 inches. WHAT SIZE ARE THEY?
My parts book does not give a AC part number for these obsolete rims. It describes them as
RIM (f/7.00x24, 7.50x24,9,00x24 Tires)    #9 may be a misprint for #8
   (Used prior to tractor B-18055) (Not available; furnish 209511 rim with four item 8 and 2 item 9) (see note)
     Note: Originally used intermittently on Tr. B-12585 to B-18055
PARTS BOOK GOES ON TO SAY
   209511 RIM for B and IB (f/8-24 Tire) (B-18055 & up) (See Note)
   After this 2 more rims have part numbers for 9x24 tires and 10x24 tires
Tire sizes to be obtained locally range from a 7x24, 7,50, 8, 9, and 10
Edited by Ken in Texas - 15 Sep 2016 at 7:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 4:13pm
    You have to look close at the tab riveted to these 1938 early 1939 original Firestone rims to see the word FIRESTONE
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 4:24pm
Here is a good B&W photograph of My Family's First AGGEN FARM Allis B. Bought NEW in 1939. See the rear rims are not painted the same PO#1 as the tractor. They look gray because they are GALVANIZED.
Photo was taken by my Grandmother at 3837 West 111th St , Chicago, Illinois.
Also see the seat is covered in Canvas Duck Cloth. Black Vinyl Seat fabric is not a correct original replacement.
Edited by Ken in Texas - 14 Sep 2016 at 5:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:15pm
Centers are the same, clamps are different, the rins have two tabs welded in one area near the air hole. My clamps have a groove that rides on the rim. The bolt is a cam that expands the lock and rides on the bumps. Being that I am sketchy on the actual year it looks like a transition tractor, I saw a 1940 that was different than mine but I do not have all the features of the 38 so I am going with early 39. The governer is non oil pressurized and I have a BE engine. The front rims are riveted hub so that is an early feature. Kinda like they were using up what they had left before they went to the 1940 model. But anyhow I am guessing either the rims were replaced or painted at one point is what I was getting at on the rear rim. Why someone would have put replacement rims on when the tractor was only a few years old is what stumps me as the tires are ancient, like early 50s at the newest. I do not have a seat yet so I still need to put together something for that, I am thinking upholstery shop.
Edited by Jonny B 1938 - 14 Sep 2016 at 7:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 7:21pm
As I was rambling I forgot thanks Ken, and galvanized it will be.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:59pm
Ken, looks like it has some sort of back cushion too. Is that factory?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:11pm
Almost looks like a rubber inner tube wrapped around the seat back. I know stitting against a JD seat back is not too comfy while bouncing around in a field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 10:23pm
Jonny
   Where is the engine serial number located on your B . The one prefixed by a BE. Is there no number beginning with a B where it says in raised letters TRACTOR NUMBER by the shifter.
   New Bs with 5/8 bolt rim clamps with a groove that fit tight against 4 rim bumps. One bump has clamp stops welded on both ends of one bump. These rims became standard in different widths after B #18055 in the 1939 production year. If you find these rims on earlier Bs they were used to replace bad early rims that were no longer available new.
   To have a good set of the early B obsolete rims with the 3/4 bolt footed clamps pictured above in useable condition is like finding a needle in a haystack
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 10:34pm
One of the Allis books states that some early tractors had black rims and some had orange rims. I have never seen 6" rims on a B. The smallest that I have seen was 7" which used  8 x 24 tires. The 8" rim is the most common.
What is your serial #? I have only seen riveted front rims on a 39. A cast iron hub was used up to serial # 9018 with a lot of exceptions listed in the parts book.
LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 10:49pm
I have to look again but my trans has B9526 on it, the engine has a few more numbers but the 9526 was in the series also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 10:52pm
That # is for a 38. I guess the rims were updated at some point. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 10:57pm
Hmm what are the chances of finding the correct wheels? I had the same issue with some Ford tractors we have with top hat rims made by Kelsy Hays but there were a lot more Fords made than Allis Bs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 11:17pm
Just looked at my wheel center disks, I do not think a 3/4 bolt would fit in there. I know the centers were never off, looks like someone tried to remove them unsuccessfully but failed as the nuts were mangled with a hammer and chisel. It took some serious pulling to get them off and the oil seals have worn grooves in the shaft in the same location so I believe they were never serviced either. There definetly was never any galvanizing on the rims either, I put some paint stripper on the paint on the inside of the wheel and no galvanizing underneath, just bare metal. I guess I just go with what I got, I got a ton of money in this project already and a pile of parts, maybe if I come across a set sometime later I might consider changing them but I would like to have a running tractor first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 11:17pm
Jonny
   The only good set of early B rear rims beside mine that I know of are on the "BUILD A B" project tractor that was in the Haymaker Museum in Paris. The B with these extreamly hard to find early B rims with all the special clamps is now in the Richard Akin collection.
   Wether he would part with them or trade for a set of 4 bumps is up to him. Wouldn't hurt to ask
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 7:30am
This is for Chalmers Bob.
I was just guessing a 6 inch rim width with old tires on. With the Tires off they measure 7 inches at the widest point and at the most at the bead flange seat 5 3/8 between the bead flanges. They are very narrow indeed.
Plan on mounting new 8.3 24 tires on these antique obsolete rims that are described, but have no part number, in my AC parts book. Used before Tractor Number B-18055
The Footed Clamps and 3/4 bolts for these obsolete rims have a AC part number in my book. 297743 eccentric clamp and 207744 plain clamp
Edited by Ken in Texas - 15 Sep 2016 at 7:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 7:53am
That's OK, it is going to get used, not a trailer queen. It will plow, go to tractor cruises and possibly get rained on once in a while. If someone has a prime example of an original low use tractor that is a museum piece I would not even ask to break something like that up. Rare original examples are what people like me doing a restoration use as as an example to have a historically correct tractor. It always good to know what is the correct parts and know what they look like in the event I should run across something just laying around or find something that some claims to be correct for sale and not get duped into a deal gone wrong. Somewhere in Arizona, South Dakota, California or Texas there is a set of rust free rims that someone just thinks is an old worn out tractor I am sure. It kind of reminds me of the top hat rims on my dads 1940 9N, I was driving one day in a local town ( Manhattan ) and there were two tractor rims propped up against a tree marked for sale. No price just sitting there by the road, they looked like they were about the right size for a Ford so I stopped and took a look low and behold galvanized original rims with Ford scripted tires. Never used, kept inside all there life so I went to the door and an old woman answered the door and I said I was interested in the tires for sale, she explained they were in the garage from her now deceased husband that had a war time tractor on steel. She said he had bought them after the war From the local dealer after returning from Germany and never installed them. After a few cups of iced tea and some conversation about the old days and that my family was big into old Fords of all types I came around to asking what the price was? She said the she still had the receipt from 1948 when he bought them and she did not feel right charging 200 dollars for the pair as they were dirty and old so she said 50.00 for the pair. At this point I was estatic and guilty at the same time because the films alone were worth more than my van I was driving at the time much less the NOS tires. I ended up mowing her yard and doing general chores for several years as a trade plush the $ 50 until she could no longer sustained the place. I gained some tractor wheels but much more, a good friend and the good feeling of helping someone in need.
Edited by Jonny B 1938 - 15 Sep 2016 at 8:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 8:32am
Love that story.
   A museum piece that BUILD A B is not. In the sense that it was built with any and all years B and some C parts from across the country with the same as B part numbers.
It was in the Haymaker Museum for a while to commemorate the event not as a correctly restored B.
I see where you are coming from now with your old B. When you get it set up for plowing post a video. It was just a year or so ago I sold a "Restored" 39 handcrank B with a hydraulic lift plow for $900
