deutz allis 5215? |
allisd2112
Joined: 02 Oct 2009 Location: Hudsonville Points: 164 |
Topic: deutz allis 5215?Posted: 11 Sep 2016 at 11:42am |
Any one have a 5215 with a 60" mower deck? Just wondering why the blades r Turing counter clockwise.so u can't mow very tall grass.belt is on right.what this a flaw in design? Any help would be great.
john(MI)
Posted: 11 Sep 2016 at 12:41pm |
I don't understand why you can't mow very tall grass? As long as the discharge is on the side where the grass has already been cut, it should work fine. The one on my AC 5020 worked fine. I quit using it because the mower tilted where there was a slight incline so the grass didn't mow level, but otherwise it cut fine.
Not all mowers rotate the same way! Maybe you put the blades on upside down? |
allisd2112
Posted: 11 Sep 2016 at 3:17pm |
No grass comes out the discharge,all clippings build up in the rear of the deck? Blades are on right. Tall grass clogs the deck with no place for clippings to go.if the discharge was on the left side it would blow out discharge?
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 11 Sep 2016 at 3:34pm |
slow down
shameless (ne)
Posted: 11 Sep 2016 at 3:35pm |
if it clogs in the middle, the belt isn't on the right way on one pulley or more.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54713 |
Posted: 11 Sep 2016 at 6:39pm |
sounds like you need a belt routing diagram...
allisd2112
Posted: 11 Sep 2016 at 8:35pm |
I got a diagram from dealer,the belt was on right.
DrAllis
Posted: 11 Sep 2016 at 8:45pm |
Well, are you a first-time user of this particular machine and mower deck?? Because if you are, there is something WRONG with it. There is no design flaw. Those mower decks were the tops in the Industry at the time they were built. Sounds to me like its running backwards. Sure wish I could be right next to it and I'll bet within 3 minutes the problem would be solved.
ILGLEANER
Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Posted: 11 Sep 2016 at 10:21pm |
I had one. Nice little compact. Something is wrong, or it would mow. IG
allisd2112
Posted: 12 Sep 2016 at 5:02pm |
The big power pulley on the center of the deck runs counter clockwise.pto.. shaft runs clockwise.there is no way I have the belt on wrong.the big pulley should run clockwise,then the belt diagram would make the blades all turn right. I"ll try to post a pic of the belt diagram.
DrAllis
Posted: 12 Sep 2016 at 7:05pm |
You didn't answer my question.....did you just BUY this thing?????????????
allisd2112
Posted: 12 Sep 2016 at 7:47pm |
Yes I did!it mows short grass nice.tall grass it just stops the blades.belt good and tight.
EricPA
Joined: 13 Sep 2009 Location: Watsontown,PA. Points: 2578 |
Posted: 12 Sep 2016 at 7:58pm |
Lefthand or righthand discharge?
Life is tough,but it's tougher when you're stupid. - John Wayne
DrAllis
Posted: 12 Sep 2016 at 8:08pm |
Well, maybe your expectations of it's capacity are too high. It's a lawn mower, not a brush cutter. I'd guess anything over 4 inches is pretty tall for a mower like that and how low do you expect to cut it ??
allisd2112
Posted: 12 Sep 2016 at 8:57pm |
Right hand discharge.my 16hp simplicity mows taller grass than thing.if I cut a hole on the left side it should work great.just a stupid way of doing it. I was just wondering if anybody else had a mower like this and the grass actually blows out the discharge! Unless I need special blades. I have ones with a curve upright bend.
EricPA
Posted: 12 Sep 2016 at 9:04pm |
That's why I was asking, my 5020 lefthand requires lefthanded blades. Thought maybe someone hooked you up with the wrong blades
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 12 Sep 2016 at 10:13pm |
Sounds like the belts are old and worn and need to be replaced.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
ILGLEANER
Posted: 12 Sep 2016 at 11:12pm |
I am just throwing things out here. Is it the correct deck for the 5215 ? Remember it is only 15 horse. And a lot bigger then a 16hp lawn mower. I could kill mine easy. You have to mow short grass with that rig. I used mine for a couple years, and sent it down the road. They are weak. Not enough motor for the size of tractor it is.
DrAllis
Posted: 13 Sep 2016 at 9:01am |
Is the mower deck nosed down?? Generally, those decks are supposed to be 1/8" to 1/4" higher in the front center. Nosed down won't work well at all.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3993 |
Posted: 13 Sep 2016 at 9:30am |
at our shop we see many blades that are not right ... rotation, lenght, bent, wore out, sharpened wrong ,upside down, loose , you name it wish i could see it we only sell and or sell a few hundred blades per year
HudCo
Posted: 13 Sep 2016 at 9:33am |
dont know about that deck but some have mulching baffles under neath bolted on
