L2 hydraulic chaff spreader
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: L2 hydraulic chaff spreader
    Posted: 09 Sep 2016 at 9:16pm
Ive asked this question before but I think I'm about to make an attempt. I have a vitetoe chaff spreader and it currently is run off to the header reel hydraulics. I got a different header and I would like it to run with the corn header so I don't have to take it off and on. Every time I switch crops. I am thinking about plumbing it into the return off of the main valve stack with a blocker valve that routes oil through the spreader when the separator clutch is engaged.
Does anybody have any experience with this. Dad is concerned the back pressure on the valve stack will make it malfunction. The only real issue I can think of is that it may lose flow when the header raises but that will only be momentarily. Any input is appreciated. Thanks. Derek in mo
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:21pm
I'll have to look at my L2. I can run it without running any other function. never really looked at how it's plumbed.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:31pm
Lonn. Thanks for responding so quickly. I'd love to know. I can send you my phone number if you want to text me pics.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 5:42am
I rarely carry a phone (I like not being found all the time) so sometime today I'll get pics and tonight I'll post them here.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 7:19am
I've plumbed one before with the power steering return oil flow. Downside is, whenever the engine runs, it will run, unless you install the speed control valve outside the cab door or window, so you can shut it off if you want it to be stopped.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 9:40am
I bet that's how mine is plumbed. I have a speed control valve outside the right window.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 6:32am
Is there a reason you used the steering rather than the valve stack return. From what I read steering only has 3.5 GPM and the valve has 11. I thought those spreaders needed more like 6 GPM. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 8:53am
My combine was a 79 model....yours sounds newer. I wouldn't use the return from the hydraulic valve stack. You do whatever you want. I know we had hyd oil cooling problems after this spinner was installed.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 3:50pm
could you change it to a 12V motor?
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:08pm
Ours is plumbed off of the hydraulic pump to a speed control, then the spreader, the return is teed into the bypass from the speed control and returns to the outside row first section on the valve stack , it doesn't have a solenoid. I assume that is the direction the oil flows. Its to dark to get pics now.
This is on a L3 which I assume would be the same.
