Old Tractor
gorillamansteve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gorillamansteve Quote  Post ReplyReply Direct Link To This Post Topic: Old Tractor
    Posted: 09 Sep 2016 at 9:41am
I know I might be asking a lot but I have no idea about this Tractor, I need to sell it and don't know anything about it. If anyone can tell anything about it from the pics I would very much appreciate it.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:47am
Model B.  serial # is located on top of transmission just forward of shifter
Edited by CAL(KS) - 09 Sep 2016 at 9:50am
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:47am
You've got a model B there. If you look by the gear shifter, it will say tractor number in raised letters.   Right next to that is a flat pad. I'm at flat pad you should see numbers stamped in - that will be the tractor's serial number and can be used to determine year. Yours is probably somewhere in the mid to late 1940's.
Edited by GreenOrange - 09 Sep 2016 at 9:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:58am
I like that clutch pedal lock, not a B expert but never noticed that before . . . .
BigMo(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigMo(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:59am
It is missing the air breather that should come up through the hood. The rear wheel weight is nice and the sheet metal looks pretty straight. It looks as though it's been sitting for a while, hopefully with the rain cap on the muffler the motor isn't locked up.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 10:06am
1 1\8 inch PTO and no holes in torque tube for cultivator brackets   Pre 1950. All of my B tractors have clutch latch.
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:18pm
From what can be seen, the sheet metal looks quite nice; especially the grill and its shell!
Dave/cvny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave/cvny Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:33pm
So if you want to sell it , how much do you want for it?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:49pm
If that tail light had the glass in it, it would be worth some money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 6:41pm
Was thinking the same thing. Tin is pritty straight. Looks like the air intake is under tractor in basket
Edited by Mikez - 09 Sep 2016 at 6:42pm
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:06pm
Looks as if there is a light dozer blade mounted on it as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:33pm
Question; was the clutch latch for hand cranking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:37pm
YEP
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:38pm
Nice tires! Original maybe?
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 8:14pm
Its got shutters on the radiator too
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 10:12pm
My Favorite with what appears to be a Myers Snow Plow mounted on it.
For sitting looks to be in very good shape.  Goes to show what my father used to say "they are made to sit outside.  Don't baby them"
I hope someone gets it and restores it.  If the motor is not stuck looks like an easy restore.  And if it is stuck may not be all that difficult to rebuild.
Just too good a looking machine for scrap.
Advertise it and you should get something for it.  Just don't let it go for scrap.
Let us know what you do.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 10:19pm
I might have to build myself a snow plow like that!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 12:47am
pull it outta the weeds, and clean it off. you'll get better bites and price on it
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2016 at 5:51am
It looks straight and fairly complete but in today's market I doubt it would grab $500 ................. if you are looking to price it.
Wink
I am a Russian Bot
