Manifold Stud Length
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Manifold Stud Length
    Posted: 23 May 2010 at 4:46pm
I need to replace a couple of the manifold studs on my WD45 - two of them are eroded away to about 1/3 original diameter about an inch back from the outer end. These guys look to be 4.25" long - is that something my local car parts shop will carry? Longest I saw in their online catalog is 3.5". Thanks!
WC, CA, D14, WD45
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 5:02pm
Give Tony a call about them, You might go ahead and get all of the studs and the brass nuts to. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:25pm
Don - checked Tony's online catalog - that would certainly work. I am hopeful that I can find a local source so I can get the manifold back on and move on to other repairs.
BTW, have any of you used a stud extractor? A friend stopped by while I was contemplating methods to remove the broken studs and offered me the use of a Craftsman (?) tool that slides over the stud and uses a 1/2" drive to force a ribbed wheel inside the tool against the stud. I worked great - I had both studs out in a few minutes.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:41pm
Yes Dave I have a Craftsman just like you are describing, It will do a good job on a stud that is 1 1/2" or so long, But not the dreaded stud that is broke off flush with the head. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 9:26pm
I was lucky - both broke off leaving 3" of stud to grab onto! I think the one he loaned me would work down to about 3/4" of stud.......but I have no interest in testing that idea!
WC, CA, D14, WD45
