MS carb numbers
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Topic: MS carb numbers
    Posted: 06 Sep 2016 at 5:41am
Just curious what is really the difference between different carbs that will all supposedly work on the same tractor?
A prime example would be a WD45. I've seen where you could use anything from I think a TSX464 to a TSX673 up to a TSX871. I understand that jet sizes and bore sizes could be different between the carbs but still seems odd to me that such a wide range of different carbs would all seemingly work the same on any WD45 engine.
This page was generated in 0.210 seconds.
