190 fuel pump
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: 190 fuel pump
    Posted: 05 Sep 2016 at 11:50am
Last week I used the 190 gas tractor for round baling, and the fuel pump wasn't leaking back then, but couple days later, I started it up to use and pump was leaking.
  Yesterday I took a pump off another 190 engine and found it to leak too, so Itook it apart and the diaphram was cracked...
  Question is, were these pumps rebuildable at one time being it is screwed together or do you have to buy a whole new pump?
 Is there a place that rebuilds these pumps or can get the parts ? Haven't called anyone yet because of Labor day weekend.
  I am thinking I might have to put an electric fuel pump on it. Can get electric pump for as little as 9 - 13 bucks.
NEW UNIVERSAL ELECTRIC FUEL PUMP GAS DIESEL MARINE CARBURETED 2.5-4.5 PSI #AW8016S $10.98
New 12V Universal Electric Fuel Pump Metal Solid Diesel or Petro 4-6 PSI #40016G $12.98
WOWSIER!!! just found this pump on ebay... US $179.75 + $12.75 Standard Shipping =$192.50 ...  Genuine
OEM Allis Chalmers Tractor 180 190 Gas Fuel Pump 74058966 AGCO BRAND
Anyone got a repair kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 1:16pm
They maybe rebuildable, Google it or on Ebay, but I went with the electric, lot less hassle and works great
festus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 1:24pm
jc
I just went through this . there is a place on the east coast that has or will put together a rebuild kit for your pump . It is a simple deal . If I heard the name I could remember , but right now when I want to I can't . I did put their information in a past post , but not sure where to find it . It may be tomorrow because I have it at work , but I will find it for you .
  A lot of guys have had good luck with the electric pumps . I tried two different low pressure pumps , but kept pushing past the needle and seat . Since rebuilding the original pump I have had no problems .
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 1:45pm
JC
 Not sure if I can mention the name on here and don't want to get in trouble . I love reading this forum and the people on here are very helpful .
 Phone number is 781-335-8860  google will give you more info
 I think the lady I talked to was theresa ?
 If you have the AC pump I think you want part FPA263
   carter pump  CK4220    She was very helpful . Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 1:46pm
It ran about $48.00 plush shipping
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 4:35pm
                                              Anything familiar??
Orangereborn
Dale Schafer
964?? 192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 5:34pm
Nope, not exactly... Yours has a slot for lever to go thru... mine has a round button that the pump lever arm fork goes above.
Partially assembled pump... Notice the offset lever. Yea, The elbow sitting infront of spring etc... but you can see the button on the end that the lever pulls down on.
 I will have to look to see what your pump rebuild kit fits,
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 5:58pm
You might try Hite Parts Exchange in Columbus, OH. I've had them do carbs, water pumps etc. Excellent work. 800-686-0043
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 9:22pm
not positive , but I think you have a carter pump . If you call that number tomorrow and send them those pictures they can fix you up . I had the offset lever ,but mine was slightly different than yours . I had the AC pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 10:41pm
Thanks Festus, it is a Carter fuel pump. No. 1005
The picture is of the parts engine pump, but it's the same as the one on the tractor... except the tractors top cover says Carter Carburetor Corporation  etc.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:29am
I`ve used electric and the done well.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 8:27pm
Well, just an update on the fuel pump issue... bought the eleven dollar electric fuel pump and put it on, in a quick fashion, I had taken old pump off but needed a cover plate... so took the inlet fitting off the pump body and took the actuating lever out , then bolted old pump back on. Screwed fitting into the inlet on new fuel filter, and screwed that to new pump and reattached fitting to line. Then put hose fitting in pressure end of pump and ran a hose over to carb where I have another big filter and connected to inlet on filter.
 Hooked up pump to ignition wire above resister and connected ground to clamp for lines and then it fired right up.   Went to bale hay and the tractor ran good for a little while and then started having starvation of fuel...  I put the ground wire under a bolt and tightened it there and it never died after that... worked really good.
 Now, I think I will put a relay in on the fuel pump and then grab the electricity from solenoid hot post, because it is flickering the amp gauge needle constantly, hopefully it will smooth that out.
