D17 engine in WD45.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: D17 engine in WD45.
    Posted: 03 Sep 2016 at 5:20pm
Ok most of you know I'm rebuilding a WD45 engine top to bottom for my WD45. Well I may be changing directions a little. I bought a complete running D17 today lol. It is a early one with bypass oiling so I will still have to convert that part. # is 7464. Will it still have the crank that gives full oiling to the rod bearings?
I already have a rebuilt WD45 governor/housing, distributer, head, and timing cover that is 100% ready to go this will all swap over to the D17 block correct?
I also already have my WD45 clutch kit. Will this work with the D17 flywheel? Can I change it to a WD45 flywheel? I also already have a NOS D17 7.25:1 piston kit.
Thanks for any help.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 6:54am
The d17 cranks were all the Same and had the full rotation grooves cut into the main bearings to oil the rods. Has more to to with the bearing than the crank.
This is all just opinion now since no one has answered yet.
You'll have to use your wd45 flywheel and clutch bc the d17 flywheel would be too big to fit into the bell housing.
The heads are the same.
I don't think you could use your wd45 timing cover. The end of the 17 crank is bigger and takes a different cover and front main seal.
I'm not sure about distributor.
Why'd you decide to change blocks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 7:09am
Can't use WD-45 timing cover unless you drill out the lower set of holes to 1/2".
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 9:47am
Well mostly because of the better crank and better oiling to the rod bearings. Plus this block won't have to be line bored since there are no shims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 9:50am
I still have to check the tractor out good when I get it home. On the way home with it right now. I think dad wants to buy it lol.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 10:56am
Add to the list posted above, use the D17 head on the D17 block,the D17 head used three 7/17" studs where as the WD45 used three 3/8" studs. I'd use the water pump off the WD45, drill the three 3/8" mounting holes in the WD45 pump out to 7/16"in it, the crankshaft pulley, drill the bore out and drill a new setscrew hole in the shaft  , or you can just let the belt run but it will not line up to the D17 crankshaft pulley with the Wd45 water pump installed. If you use the D17 timing cover you might need to grind a little off the right side to clear the frame rail or grind some of the rail off. Check the clearance under the timing cover to front motor, you might need to shin it or grind some off it. If you use the WD45 manifold on the D17 head might need to drill the mounting holes out to 7/16" from the 3/8" holes the WD45 used. This is the short list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 2:21pm
Ive already had my WD45 head redone. So it looks like I'm not going to do the swap. I have way to much money in my WD45 parts I thought they would all swap over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 3:57pm
I don't need the tractor I just got it cheap. I cleaned points and carb and it runs great, no smoke, no noises in bottom end, good power. All the gears shift smooth, power director and pto work. Tires hold air but are shot so are the rear rims. All hand controls are complelty wore out and some have baling wire on them. Really just bought it to part out for more money to go towards my WD45.
Edited by 79fordblake - 04 Sep 2016 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 8:02pm
There she is. Used it to mow this afternoon it has plenty of grunt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 9:17pm
You get used to running the 17 and you'll want to keep it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 9:35pm
I do like it already that's why I need to hurry up and sell it or part it. I can't keep it. I bought it to make some extra cash for my WD45, it was my Grandpa's. To be nice the D17 needs quite a bit of work but it does have a good engine and trans. Tires look like they are ready to blow any minute and rear rims are rusted out. I know how much more money I'm needing to complete my WD45 engine so that's why I'm leaning towards parting the D17. I didn't give much for it but with the wheel and tire problem neither is anybody else as a complete tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 9:42pm
I'm with Brian, keep it and pull an Eldon and switch the rears from the WD45 to the D17 and use it and rebuild your WD45 as money come's along, then after you get her ready switch them back, sell the D17 and don't get in a big rush on the WD45.
You need a backup for now. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:53am
Lol my wife will kill me if I don't get rid of this thing. :)
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 12:19pm
It's easier to ask for forgiveness than permission.lol!!she probably gets most everything she wants,she'll understand eventually.Thumbs UpBig smile
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 5:01pm
I would keep the d17. I have one getting a motor job now love that tractor.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 9:53pm
The rim and tire I can see don't look bad at all.  Sounds like you are trying to justify to yourself getting rid of it or parting it.
Why would you want to part out your grandpa's tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 3:55am
The D17 isn't my Grandpa's tractor. The WD45 is and I'm 3,000 grand deep in a engine rebuild for it right now. I have the D17 in classifieds. I want to trade it for a good WD45 with good 4 bolt wide front and factory power steering.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:04am
I would like to get an early D17 engine block like the one in the picture. My early D17 has a later block which has a different oiling system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 12:22pm
Got a WD45 to trade? Lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 5:55pm
The complete tractor or just the engine block. I have a real nice WD45 engine block I would trade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 6:33pm
A complete tractor lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 8:57pm
Not sure how "worn" the D17 really is, but I sure enjoyed discing with mine (ours) today!
Lots of power and the power steering was very comfortable too! Just saying!:) The picture doesn't look any worse than mine. (but my rims are pretty good).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 4:00am
It's not a bad tractor it runs great. But I didnt buy it with the intentions of keeping. I'm not worried about nothing but my WD45 project. That's why I would like to trade for a good WD45 with 4 bolt wide front and factory power steering. Then I can do some parts swapping with the two WD4s.
