Major issues with 190
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Topic: Major issues with 190
    Posted: 02 Sep 2016 at 3:23pm
I was bush hogging the other day and a back story all my fluids were full. Everything was working like it was suppose to...now I was mowing and all of sudden the tractor wouldn't move at all. PD nothing. The thing is all the hydraulics works just fine the pto was still running but it was like the clutch went out in it. So made the call to my dad he came over he said there was nothing wrong with the clutch...so it has to be in the PD I assume I just replaced it 3 years ago....I think the PD exploded in it and is that possible. I haven't put any pressure gauges on the PD yet any suggestions out there.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 3:29pm
might seem silly but make sure you didnt have some tall weeds pull the cotter pins and knock out the pins in the linkage that run the pd valve.  if the pto is working its in the PD whether its oil or mechanical related or in the transmission
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2016 at 10:29pm
If is a early 190, spider gear pin fell out.    MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 8:11am
Still have power steering?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 8:20am
shift gears - without pushing in the foot clutch - should grind - if not lost the center in the clutch if it does, check above suggestions... while watching the PTO making sure it is engaged.  IT should turn, and stop when push clutch in.  Never seen a PD TOTALLY fail all at once unless lost oil supply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 10:27pm
Brush cutter was still working, so has got to be PD or spider gear pin. I guess it could have broke axel or some other shaft which would be almost unheard of.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 2:30pm
Yes I had power steering and the pto runs and stops as it should. Is there away to check and see if the spider gear pin fell out without tearing into it. When this all happened I did have a hydraulic leak under the console, but when we checked the fluid levels there was just enough to show up on the PD dip stick. Does anyone know of anybody works on allis that knows what their doing located in south east Indiana.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 3:06pm
If you drain all the hydraulic and transmission oil, you can remove the PTO shaft and look in thru the hole and see it. Three bolts and a flashlite and 15 gallons of drained oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 11:53am
Ok I have checked PD pressure I have pressure on the high and low side. The pin is in the rear. But I don't have any pto now. When I bush hogging and I heard that pop the mower was running. I was doing some reading could there be an input shaft that broke. Does anyone have any other suggestions.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2016 at 12:19pm
Next thing I'd do is remove pd valve body and cover, drain oil first, to have a look inside the torque tube. If everything looks ok take the top off trans and see if you see anything.
Leon
