factory duals for 180
joshjohndeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Topic: factory duals for 180
    Posted: 22 May 2010 at 11:22pm
i have a very old original production parts book from my grand father for d-17 tractor in the parts book it shows a hub assembly that bolts up to the final drive with the wheel on the tractor. the hub assy is to mount another poweradjust rim/tire assy to for factory adjustable duals. has anyone ever seen this and did they make on to fit a 180 ?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 11:31pm
have ya got a picture you can scan to put on here?  got my curiosity up...
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshjohndeere Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 11:59pm
yes i will try to scan it and get it on here it looks like u bolt on the inner dual with 2 bolts to the final drive, then put the dual hub up and put the remainder of the bolts in. then bolt the outer poweradjust rim assy. to that.
This page was generated in 0.140 seconds.
