F3 hydraulic fluid
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 hydraulic fluid
    Posted: 31 Aug 2016 at 6:16am
This may have been asked in an earlier discussion before, even by me but I don't find it. My F3 manual specifies Dexron II for the hydro drive/hydraulic system which I know has long ago been upgraded. In reading labels of the latest versions of Dexron, some say replaces Dexron II, some say do not use as Dexron II. What do you guys use? I am looking at either Dex/Merc or Dexron VI I think. Thanks.
Edit for typo
Edited by Ben (MI) - 31 Aug 2016 at 6:19am
Part time farming with a 1980 7060 and 1984 F3 hydro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 7:08am
Who says don't use Dexron?? Later model Gleaners in 1997 ?? started using Power Fluid 821XL tractor hydraulic oil, but I don't remember any F-3 using that. Stick with Dexron or it's replacement (Dex 2 or 3 ??) You'll never be able to completely drain all your old oil out, so you'd be mixed apples and oranges together if you switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 7:37am
Thanks. I was just comparing labels on the bottles which caused confusion. Dexron VI is the latest I think, labeled as replacement for II. VI it will be.
I just wasn't sure about dex/merc labeled fluid I guess.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 2:09pm
The Dexron is backward compatible.  That is, if something called for II, you can use III or VI.
