WD not running smooth
NH in MD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NH in MD Quote  Post ReplyReply Direct Link To This Post Topic: WD not running smooth
    Posted: 22 May 2010 at 7:27pm
Here's what I have checked so far: 1) 82-85# compression on each cylinder (wd manual says 110 is standard); 2) valves checked for proper clearance; 3) new ign. wires with mag putting out spark at each plug; carb. overhauled and then replaced with a rebuilt one that was test run on another tractor.  The engine starts instantly and has good oil pressure, and it runs with no smoke or odd noises.
Would 85# compression instead of 110 cause the engine to run roughly or are there other things that I should check?
Thanks.
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 7:52pm
Not running smooth doesn't give us a lot to go on. At low idle? At high idle? Any rpm? Is the spark sharp and blue? Maybe try spaying carb cleaner around the intake manifold while it's running to check for a leak in the manifold. RPM's will normally increase if it sucks cleaner through a hole. Maybe tweak the timing while it is running. What else???? I don't know. Now you got me talkin to myself again. LOL
 Will it smooth out if you choke it a little?
Edited by CTuckerNWIL - 22 May 2010 at 7:53pm
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 7:58pm
burned valves or worn seats would.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 8:37pm
Have you adjust the carburetor to this engine? Carburetors from that vintage are not preset and need regular tuning. Running rich or lean will make for rough running.
Gerald J.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 10:46pm
Compression variance is typically all cylinders should be within 10 percent of each other.....yours is low, but balanced.
If the above suggestions don't fix it, try replacing points and condenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NH in MD Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 12:45pm
Thanks for the follow up and ideas on this.  Here's some more details in answer to your questions..
-Runs rough at all RPMs.
-Does not help to put the choke on to try to smooth it out.
-Manifolds were recently reinstalled with new gaskets and red RTV, so I don't think they leak.
-Moving the Magneto back and forth in adjustment does not help.
-When I pull the ign. wires out of the magneto when engine is running there seems to be a good spark.
Could the person be right who mentioned burned valves or worn valve guides possibly be right?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 1:37pm
When you say it's running 'rough'... do you mean that it misfires on random cylinders?  Does it drop one or two cylinders consistently?  Does it pop and crackle?
One of the things I've learned about these magneto ignition systems, is that ust because it appears to have good spark, doesn't assure that it's totally good.  A local feller here has his own magneto shop, and went through several of mine, all seeming to have good spark, but generally poor running result.  After he went through 'em, they all run solid-as-can-be.
Magnetos have ignition points and a condenser, just like battery-coil.  The points need to make good contact, and to do so, they need appropriate dwell, spring pressure, clean contacts, and proper phasing with the spinning armature.  THEN, they need strong enough magnetism in the frame, and finally, in order to generate a suitable firing pulse, they need a good condenser.  Any ONE of these items will cause you to have an unstable spark, or a spark event insufficient for lighting off a mixture in the chamber.
Last, but not least... your magneto has an impulser, which not only causes the armature to 'flip' fast on a low RPM start, it probably also retards the timing event past TDC for a safe and easy hand-start, and then... advances the spark when it's time to run.
I wouldn't discount the valve question, but before digging into the head, I'd certainly yank the mag and take it to someone who really knows mags well... what you're describing sounds like either the magneto is unstable at any speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 4:12pm
If it idles rough then seems to run better at high rpms and adjustments on two different carbs. have no affect . then its a burned valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 5:24pm
""-Manifolds were recently reinstalled with new gaskets and red RTV, so I don't think they leak. "
Why RTV? If the manifold is flat and the head is flat the only thing that needs to be between them is the gasket. If either surface is not flat, it should be milled before assembly or you will be fixing later. Any new assembly can leak. It don't matter to the leaking manifold that you "think" it doesn't leak and an easy check with a can of brake clean or WD40 will tell if it does.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:19pm
Check firing order. should be 1-2-4-3. Gas cap vented?
