Wd LOst oil Pressure
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Topic: Wd LOst oil Pressure
    Posted: 29 Aug 2016 at 4:30pm
Had my WD idling this morning and suddenly it lost oil pressure. Took line to oil pump off, still no oil pressure. Cal in Ct
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 5:14pm
Maybe take a look at the oil pressure relief spring. If it broke, you may not get oil to the filter base. Did the engine start to rattle or knock? I hope not Shocked
 If it had oil pressure and then went down, could be from oil warming up and thinning out or, something blocked the suction screen?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 5:59pm
Like Charlie said check to relief spring/plunger, if it looks OK, you might try priming the oil pump with some new oil through the oil filter feed line coming out of the block, then drain the oil and use a ice pick to push up through the oil pump screen on the oil pump if it moves the pump, mounting bolts have come out. after this short check list then and only then drop the oil pan and drop the oil pump out check the driven gear on the pump and the camshaft oil pump drive gear , oil pump driven gear pin and open the oil pump up look at the two gears inside the pump and the oil pump drive shaft, cover and gasket.
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 7:16pm
Same thing happened to me with my wd45 I lost oil pressure after a head gasket replacement turns out something got under the relief plunger.
After I cleaned it out it worked fine .
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 7:39pm
This is my pulling tractor and it runs stong, but has a block leak at the bottom between 1-2 it has been like this for years so I only run water and drain before use I was warming it up to change oil. I only pull in the classic stock class. The local fair is fri. nite and don t want to disappoint the grand kids. I will pull the relief valve in the morning. I will keep you pnformed. Cal in Ct
This page was generated in 0.050 seconds.
