B final drive seal and bearing #s
Jonny B 1938 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Topic: B final drive seal and bearing #s
    Posted: 27 Aug 2016 at 11:39am
Well I got one side apart on my 39 B with HA gear drop boxes. Does anyone have a list of the required bearings and seals for the final drives? I tried crossing the Allis part numbers and got nothing so I thought I would ask the orange gurus before I drag it all down to Motion Industries for match up. Thanks..... Jon
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 6:42pm
B FINAL DRIVE BEARING AND SEAL #s
Rear axle
Outer cone 368
outer cup    362
outer seal   415001
inner cone   14138A
inner cup    14276
Pinion shaft
outer cup   14676
outer cone  14138A
inner  cup   14276
inner cone   14138A
seal            450456
The numbers on the cone and cup are standard bearing numbers, not Allis numbers.
Bill B
Edited by wbecker - 27 Aug 2016 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2016 at 1:06am
Thanks, the numbers on my stuff are hardly legible, the seals are pretty beat up from disassembly and weathering and my eyes are not that great either LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:20am
Another "SUPRISE", three of the bearings and races measured the same so I guess I got another odd ball. The outer axle bearing is of course larger but the others are identical. The numbers were etched in on most of the stuff and are unreadable after rust and heating from removal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 1:55pm
Yes 3 bearings are the same. No surprise.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny B 1938 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 1:27pm
OH OK by the numbers they appeared different, a couple numbers above did not come up on the Motion site so I was kinda confused till I started to look at it.
