7050 and8030 keeps loosing fuel pump prime.
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Topic: 7050 and8030 keeps loosing fuel pump prime.
    Posted: 12 Aug 2016 at 8:21pm
Sounds so easy and simple to figure out I shouldn't even need to ask, BUT.....
We have the twoo tractors and both loose their fuel pump primes if they sit for more than a day or two and the fact I can't track down where  the air leaks are is driving me nuts.
With both 3 - 4 pumps on the hand primers and they start right up, followed by a few seconds of sputters and surging while they push the remaining air out, but if I don't they are air locked hard and will not come out of it on their own.
SO what am I missing?
is there a common seal or something that ages and starts working like a check valve keeping system pressure in when I try and test it but lets the fuel drain back out after sitting for a  day or two or what?
I've power washed them clean in order to look for drips or seeps and I got nothing even after hours of running yet after a day or two of sitting their pumps are air locked again.
Edited by Tcmtech - 13 Aug 2016 at 11:49am
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:00pm
Same problem on my 8070, long story short, the return line from the pump goes to the left side fuel tank to a fitting on top of the tank. there is a line from that fitting that goes to the bottom of the tank that had fallen off. once i replaced the line all was better. With the hose on and in the bottom below the fuel line the fuel will not drain back and loose prime. Not sure about the 7050.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:38pm
Take the hand pump apart. There is two check valves that gets foreign matter in them. Clean check valves and replace o rings.       MACK
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:42pm
I 2nd the reply MACk gave you.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:42pm
Replace all the rubber fuel lines they are letting air in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 9:56pm
Sorry. Forgot to mention the two primer pumps had both been gone through and the problem never improved.
I was starting suspect it may be a fuel line issue but after the washdown and wait the fact that I never got so much as a noticeable drip let alone damp spot had me ruling that out and that there had to be some seal or O-ring I wasn't finding that was giving me the problems.
I didn't think about there being a dip tube on the return line but that is worth looking at as well.
IF that not it I think that a full replumb of both is  on the list.  The having to pump them up every time I run one is getting old.
Thanks!
(Now if only one of you guys only knew the working pressure range for my MF 2745 multi power hydraulic circuit so I could replace that bad Hobbs switch I'd be almost be set on the bigger tractor repair work for a day or two and could get into the smaller tractors next. Cry)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2016 at 11:39pm
the bad thing is ,you can leak air in but it won't leak fuel out....very hard to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 6:28am
Bingo fuel line is relatively cheap at NAPA not sure how you would find it.   My 7060 did this neighbor told me about this I thought he was nuts. Problem was gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2016 at 11:50am
New fuel lines it is then.  Wink
