Allis Model c stops
kd8ajc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kd8ajc Quote  Post ReplyReply Direct Link To This Post Topic: Allis Model c stops
    Posted: 03 Aug 2016 at 4:17pm
I have a 1947 Allis Chalmers model C that was my Grandfathers.  It began acting as if the idle kept getting slower till it stopped. I have rebuilt the carb and it will run from 45 seconds to 2 mins then slows down as if someone is pulling the idle till it stops. I have been told this is a float issue so I put the original float back in and it runs a little longer. What else could this be?  I have a Zenith carb and the float valve seems to work fine.  Could this be a sticking throttle shaft?  I have done nothing with the governor. Could the thrust bearings in the governor be bad?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 4:21pm
I agree.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 6:42pm
More than likely it is a fuel obstruction somewhere between the bottom of the tank to where it leaves the carburetor.  I would either remove the sediment bowl from the tank and clean it first and blow thru the gas line from the carburetor end.
The only true way to clean a carburetor is to soak it in a basket of carburetor cleaner. For that size of carburetor they sell a gallon can with a basket.  I personally boil any carburetor I am cleaning before I take it apart. Some times I boil it again if it is real cruddy before I soak it in the cleaner.  The carburetor cleaner in a spray can will not do what is needed. It works best to clean your hands or the outside of a carburetor while using a wire brush.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kd8ajc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 7:07am
Thank you and I will try that out.  James
